First diesel questions
you might have some oil blow out if they put the oil up to the full line instead of the half way mark. oil change place did that the first time on my 03 put 12 qts cuz the book said so, only works if complety dry. as far as the black color havent known a diesel yet that the oil wasnt black. a little drip is no biggie if it gets bigger then theirs a problem, check the oil filter its been loose on mine before
From: somewhere in northwestern ohio....Mansfield, Oh
If oil does not get black I would be worried about the quality of the oil I was using , it's job is to encapsulate the dirt . Oil that stays clean is not doing its job , no mater what oil you use there will still be soot getting past the rings and if it is not being pick up and run through the filter it stays in the engine .
First oil change should probably be within the first 5,000 miles and after the 2nd oil change along those intervals go ahead and start pushing out there. I say that and I change mine every 5,000 period as long as I'm running dino oil, I'll move it out there aways when I switch to synthetic. And my dealership the last time charged me $129, so I've been changing mine since.
Okay guys, I just got my first diesel two weeks ago. I'm going crazy getting used to diesel. It is a 2001 5.9 turbo cummins 2500. Oil changes (I've been told every 3000 miles) engine has 122,000. Oil filter NAPA (wix), fleetguard, or K&N.? Fuel filter- Mopar, NAPA, What? I drive stop and go in Seattle but pull a boat on nice days. I need your help. Please. Oh yeah, this fuel additive question. Is it really necessary? What type of additive if it is?
How often? By the way this truck turns 765 Ft of torque and 385hp on the dyno. Runs great.
As for fuel additive no its not required but a Qt of 2 cycle outboard oil in the tank sure will help to lube back in to the fuel (& helps the fule system) that ULSD lacks. Many use an additive as some have anti gel in it to keep the fuel from geling between 20 above and all the way down to -40 below zero. Oh some also have a centane boster, this is the same as octane boster in gas but made for diesel fuel.
209trucker
Sep 28, 2013 07:06 PM
97CTD
Jul 29, 2007 08:22 AM
1stTimeAround
Oct 10, 2004 04:02 PM
BulletMan
Oct 31, 2003 10:02 AM
