Exhaust filter full
Old May 9, 2012 | 04:57 PM
Fast Eddy's Avatar
Exhaust filter full
Will the truck continue to run if i delete the dpf until my Smarty jr comes in.
Old May 9, 2012 | 05:17 PM
RamGazer's Avatar
10 Year Member
Sorry I can't answer your question. Just wondering, are you in limp mode yet?
Old May 9, 2012 | 05:20 PM
Lil Dog's Avatar
In short no. The system will limp if it doesn't see a pressure differential across the DPF. IF its plugged, you can get the dealer to do a forced regen using a star scan or grab a coffee and go for a 1/2hr highway drive.
Old May 9, 2012 | 05:25 PM
Fast Eddy's Avatar
Yes it is in power reduced mode.Never went into regen for some reason
Old May 9, 2012 | 07:46 PM
orr's Avatar
orr
When my truck had the DPF and it did the same thing I was in the middle of Jasper during a white out. Advice from the dealer was to disconnect the battery to reset the computer. It would come out of limp mode for about 200 or so K, then I'd reset again and off I went. I would assume you could do the same with the DPF out. The dealer replaced mine under warranty and I drove it for another 60,000 or so. I had no problems with the truck afterwards, now 120,000k later. Hope this helps.
Old May 9, 2012 | 08:52 PM
RamGazer's Avatar
10 Year Member
Mine went in limp mode (when I owned my 2007.5 6.7L) out near Ft. Davis Tx. towing my T.T. (nearest major town was Odessa). Took it to the dealership back in Dallas and they had to replace it as it was faulty. Hope you don't go through that mess. Good Luck.
redlineguy
15
Jan 9, 2012 09:15 PM
13bdarren
Jan 27, 2009 12:39 PM
West Coast
Jul 4, 2007 10:25 AM
j
Nov 14, 2003 09:38 PM
