Engine studders
I have a 2009 6.7 2500 auto transmission with full deletes and I need some help. I was driving to work today and all of a sudden my truck started jerking like someone was slamming the brakes on. I just rolled over 80K so I pulled over into a parking lot and did a visual inspection of the front end and drive lines, no visible issues. I've replaced the front wheel bearings and all the u-joints in the truck so I didn't think that was the issue. I was only about two miles from work in a 30mph zone so I decided to limp it to the parking lot. When I got there the engine started acting weird, it would shake and almost cough when accelerating so I'm thinking something has gone horribly wrong
! When I stopped in the parking lot at work I shut down the engine and tried the three key trick to check for codes, nothing. I tried to start the engine and it took almost 8 seconds of cranking to get it to fire. I checked for codes again, nothing. I shut it down and restarted it, engine shaking has reduced but it still seems like it's running on 5/6 injectors or something is choking it off. I did read something on a post about turbo cleaning, is that a real thing? I mean drilling a hole in my turbo seems a bit dangerous. Any help on this would really be great. Thanks! -Mrhyde
Correct, no CEL and no indication that the lift pump is going out. I did try the remote start and it started just fine but keeps shaking the whole truck side to side. I'm starting to lean more towards a bad injector. Once I get it into a garage I'm going to redo the flash on the XRT programmer and check with a ODBII code scanner to see if there are any codes showing up. Any other ideas?
muddin_mavric
18
Sep 18, 2007 06:34 PM
daysel
Aug 21, 2006 09:17 AM
