engine light
Old Apr 19, 2009 | 07:00 PM
dodge1962's Avatar
engine light
I have a 08 it will soon be going back to the dealer cause the check engine light is back on. this will be the fourth time in a year always for the same thing failed to regen truck has 21000 miles on it, is everybody else having this problem, tired of going back to dealer. on the overhead it always says system ok. would lemon law work in this case.
Old Oct 12, 2009 | 10:34 PM
mrich30's Avatar
I'm having the same problem with my 08. The service rep told me it's going to keep happening if I drive in the city a lot. He also told me not to drive with the cruise control on for any long period of time. Also don't turn off the Jake brake as it helps keep the filter clean. I just bought my truck two days ago after trading off my 99 dodge with a cracked block. I'm very frustrated right now since it's only been on the road for one full day and now it's been gone for two. Good luck
Old Oct 13, 2009 | 10:53 AM
notrader's Avatar
I have had the light twice. Hopefully the last software update and the changeout of some oxygen sensors has fixed the problem. but as I have read on this forum and another forum, cumminsownerz.com , you can not drive these trucks like gasoline and older diesel engines. you can't let these engines idle, they have to be working. it is best if you can drive them for an extended period at operating temperatures. no short trips. find a frwy on ramp and sock it to it to make the turbo operate. run with the ebrake on.
yes, you may have to change your driving habits to own one of these trucks. i am going to give this truck an opportunity to prove it can be reliable, if it can't, i will probably go back to gasoline, just because the environmentalists have caused the manufacturers to make the diesel too inconvenient to use.
Old Oct 13, 2009 | 02:04 PM
mega-engr's Avatar
"California Style"
I wonder if the EPA took these hammer down driving habbit changes needed into account when they decided to lower our MPG and make us pay a premium for the bluetec system. Doubt it.
Old Oct 14, 2009 | 09:17 PM
Gypsyman's Avatar
Delete the emissions systems and the truck will run like a dream. You become your own warranty station but you'll probably never be back at the dealer for repairs.
Old Oct 14, 2009 | 09:20 PM
Lil Dog's Avatar
Quick tip.. always keep the revs up. For me in town it never gets above 4th gear, I select 4th every time and only 5/6 on the highway. Having it idle around at 900 rpm in 6th will cause it not to regen properly. Never had an issue and I don't "drive" the truck any different than my 97...
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
99gt
Mar 24, 2010 09:13 PM
choppers555
Oct 16, 2007 12:29 PM
Stevenc
Dec 28, 2004 08:29 PM
