DRB Diagnostic Tool update
Old Feb 9, 2008 | 02:17 PM
realoldandcrust's Avatar
What do I need to use the DRB tool on a 08 Cummins 6.7? I would like to monitor engine values, do parameter comparisons etc. The tool has been used on a 05 with limited results. Do I need a PCMCIA card, Tool Flash update????
Old Feb 9, 2008 | 08:59 PM
gmctd's Avatar
Even the latest DRBIII needs updating yearly to keep up with the new stuff - see yer fav MrMoservice guy - possibly he can help - and do that B4 you try to connect with your DRB - a 6.7 UPCM\BCM\TCM is a terrible thing(s) to waste..............
Old Feb 9, 2008 | 11:52 PM
Power Ram 4X4's Avatar
you have to use a star scan for 06 and newer trucks.
Old Feb 10, 2008 | 10:20 AM
bob4x4's Avatar
The drb3 is not designed to work with a can bus vehicle,it is way too old and slow to even think about anymore upgrading.
Bob
Old Feb 10, 2008 | 12:19 PM
gmctd's Avatar
Autoenginuitydotcom sells a laptop software scantool that talks OBD2 and the Enhanced stuff - gives rail pressure and all that enhanced stuff, works well on the Bosch CRD Jeep system, similar to the '03-'06 5.9 Bosch system, just less 2 cylinders, but have not tried it on a 6.7 - it uses a special enhanced adaptor for the CAN buss stuff - check'em out...........
Old Feb 12, 2008 | 05:34 PM
Diagnostic Tool
I looked into this laptop diagnostic tool. Sounds very impressive. However, the down side is they are just this week releasing the 2007 software for the enhanced tools. I need the 2008, so I will need to wait another year.
Are there other tools that have been released that will read 2008 data?
Old Feb 12, 2008 | 09:25 PM
gmctd's Avatar
'07.5 was specifically different than '06-'07 because of the 6.7\68RFE\68ASA - should be no changes or little changes '07.5 to '08 - 'sides, the software updates are free if you have the Enhanced license from the previous year(s), maybe back to '04, when DCJ CAN began in earnest - that's what Enhanced is all about, takes a special DLC interface module to use the Enhanced software - it reads all the data in the 2.8L Jeep CRD, which is totally Enhanced, with the TCM for the little brother to the 68RFE, the 545RFE - guess I should surf on over there and investigate the upgrade - see ya...............and, back again
Ha! Ya had me worried - latest release is 5.4.1 JAN08, so what's to worry, eh?
Been there - done that - got it...................
madhat
Oct 13, 2010 07:04 PM
highpie
18
Mar 4, 2008 07:09 PM
Homestead
Dec 22, 2006 05:38 PM
Tazman
Oct 1, 2004 09:28 PM
SoCal-305
17
Aug 8, 2004 11:19 AM
