DPF delete? What kit?
For the best inexpensive kit go with the H&S delete from rollinsmokediesel.com I had mine in just e few days and price was under 650.00 for the turbo back kit. He is super knowledgable on these trucks.
Chris
Chris
I bought the dpf-r kit and it has yet to throw a code. I fabbed up my own delete pipe too which saves a lot. PM me if needed for futher info on this. www.dpf-r.com
I agree with Chris, I have been dealing with Rollin Smoke and have loved it. There customer service is great. I got the 6.7 Stage II kit, (aFe intake, edge juice/att, and H&S stg 2) for 1750 bucks.
on the new H&S kit there is a box that plugs into the pressure sensing moduale on the side of the trans that controls when the DPF regens. My kit was the older model so It did not come with it so other than knowing what it does kinda I have no first hand knowledge. If you have a code clearing modual like the Edge theen it is not really needed. If you are not running the boxes then I guess it helps with throwing codes but not eliminate them
Chris
Chris
yes the electronics need to be fooled. A $1 worth of resistors from radio shack will solve the regen problem but the odds are that you will have a check engine light. Check out the C&C section on Cumminsforum.com as there is a step by step with pics. If you can weld you can make your own kit for under $100 including the delete pipe.
Thanks for the information.
So, the 2 pressure sensors on either side of the DPF are telling the ECM when exhaust flow blockage is occurring/present. Anyone know if the ECM looks for a pressure differential only, or if it looks for a minimum post-DPF value and/or a maximum pre-DFP value?
Also, what do the 2 oxygen sensors on either side of the catalytic converter measure in terms of voltage? Anyone know which of the 5 wires need a resistor across them?
