Cruise control
Hi,
I am having trouble with the cruise control, when I turn it on and set the speed it works okay for a while then it seems to stop working when you hit a bump in the road. I try to set the speed again but will not work, not sure what to do?
Can someone tell me where the cruise control unit is located in a 2007 dodge ram 2500 6.7l so I can check it out.
Cheers
Cheers
As far as I know the cruise control is all electronic and part of the ECM programming. I would think it may be a switch problem with the brake pedal. If its worn or a little loose, the lights may not come on but it will be enough for the cruise to think the brake pedal is on.
Check out my post. You might find your answer. https://www.dieseltruckresource.com/...y-t311179.html
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
