Clearing perform service light
Old Mar 2, 2011 | 02:47 PM
thaimonkee's Avatar
My overhead display reads "perform service" which i was told to replace the CCV filter. I just replaced it and was wonderong how to clear it. I couldnt find it in the owners manual. Thanks!
Old Mar 2, 2011 | 04:31 PM
cbrahs's Avatar
https://www.dieseltruckresource.com/...e-t284851.html
Old Mar 2, 2011 | 06:14 PM
thaimonkee's Avatar
Thanks for the link. Maybe i mistyped it. I want to clear the "perform service" light on the overhead console sInce i just replaced the CCV filter.
Old Mar 2, 2011 | 08:58 PM
cbrahs's Avatar
post #8 in that thread.
PERFORM SERVICE INDICATOR - RESET The “Perform Service” message will display on the EVIC each time you turn the ignition switch to the ON/RUN position to indicate a emission maintenance is required. To reset the “Perform Service” indicator system (after performing the scheduled maintenance) refer to the following procedure: 1. Turn the ignition switch to the ON position (Do not start engine). 2. Press and release the brake pedal two times. 3. Fully depress the accelerator pedal slowly two times within 10 seconds. 4. Turn the ignition switch to the OFF/LOCK position. NOTE: If the indicator message illumination when you start the vehicle, the “Perform Service” indicator did not reset. If necessary repeat this procedure.
Blacksunshine
Mar 2, 2012 09:34 AM
bekec
Feb 14, 2011 09:16 AM
SilentTrouble
Oct 14, 2010 10:55 PM
Outwest
Oct 19, 2009 07:38 PM
GMScott
Nov 2, 2007 03:01 PM
