Block Heater
Old Jan 19, 2009 | 09:52 PM
Racfan9's Avatar
Block Heater
I was wondering if there is anyway to tell if your block heater is working? I just installed the electric cord on my 2007 5.9 anyway just curiuos.
Thanks, Racfan9
Old Jan 19, 2009 | 10:09 PM
madhat's Avatar
Administrator/Jarhead
You should hear the coolant bubbling after a few minutes, and you can touch the block near the heater and it will be warm. If you have an edge with attitude or another monitor that tells you what the engine temp is digitally, you can look on that before you crank the truck, I remember my showing around 100 degrees before I started it, I think.
That, and the truck should start a lot easier, and the heater will almost be warm when you get in it...
Old Jan 19, 2009 | 10:13 PM
ChrisM55's Avatar
After it's been plugged in all night my grid heater indicator (wait to start) is not on when I turn on the key.
Chris
Old Jan 19, 2009 | 10:40 PM
madhat's Avatar
That may very due to location, tho. Sometimes mine comes on, sometimes it does not.
Old Jan 20, 2009 | 07:14 AM
ChrisM55's Avatar
when it was -2 here a few weeks ago it never came on when the truck was plugged in. Edge said the negine temp was 94
i would say if you have yours plugged and the grids come on before you start either the extension cord is WAY too small or it has a problem, or there is a heater issue
Chris
Old Jan 20, 2009 | 07:18 AM
madhat's Avatar
I may not have had it plugged in long enough, either...
Old Jan 20, 2009 | 07:22 AM
madhat's Avatar
Try this, too...
HEATER
If the unit does not operate, possible causes can be
either the power cord or the heater element. Test the
power cord for continuity with a 110-volt voltmeter or
110-volt test light. Test heater element continuity
with an ohmmeter or a 12-volt test light.
If you have to remove it, I can give you the removal and install procedures, but it's very simple... just take it out... might want to drain some coolant first, and the t-stat would have to be open for the coolant drain on the rad to affect the coolant in the block...
Old Jan 20, 2009 | 09:48 AM
ChrisM55's Avatar
yeah, it takes a while once you plug it in. Another thing too is that if it is dark you can see an ark inside of the plug when you plug it in or unplug it if the truck is cold
Chris
Old Jan 20, 2009 | 12:58 PM
jerry007's Avatar
It takes a couple hours for mine to get a litlw warm, at least 2-3 hrs.
Old Jan 20, 2009 | 01:21 PM
Scotty's Avatar
Top's Younger Twin
I will get the wait to start light in very cold weather. Right now it does not come on and we are around -15C. When its in the -25 and colder, it comes on even when plugged in.
Scotty
Old Jan 22, 2009 | 04:51 PM
Glasshog's Avatar
No wait to start lights for me either. It stays plugged in over night when it's cold, but it's not ever below zero around here. Also, I keep the defroster open/on and it keepsd the windshield clear of frost or ice.
Old Jan 24, 2009 | 03:49 PM
buzzinhalfdoz's Avatar
after 1.5-2 hours the water neck will be warm...
Old Jan 25, 2009 | 02:19 AM
DaveB.inVa's Avatar
After a few hours it makes the intake air horn warm! Admittedly I don't really need a block heater in my location but its nice to be able to get cab heat a lot quicker.
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
Reelay
Dec 1, 2005 06:14 PM
