After Market Air Filter?
Old Nov 10, 2010 | 04:58 PM
mxmike27's Avatar
Wow, thats an eye opener !
Old Nov 20, 2010 | 04:00 PM
J BODY's Avatar
For warranty purposes I would stick with the stock air filter. Also.....changing the airflow changes fueling which can create soot. Oil/gauze filters can coat sensors causing issues down the road too.
Old Nov 21, 2010 | 03:42 AM
HMX-1's Avatar
You really don't even need the tests to see there's a problem. Just take one of the K&N's off a regular gasser and hold it up to the light.
You'll see tons of tiny holes in the filter ...... and once you see that, it will cure your desire to use a K&N filter.
Kris
Old Nov 21, 2010 | 09:28 AM
.boB's Avatar
What is your goal? If it's simply a good filter you want to kep the truck alive, then a stock replacement from Baldwin or AC Delco is your best choice.
But if you're looking for more power or better mileage, you're wasting your money.
Old Nov 21, 2010 | 12:14 PM
NavyDood's Avatar
Save your money. The OEM filter is all you will ever need up to 500 HP. You will gain nothing in MPG or power.
Here's some newer data.
53034249AA (New Dodge air filter) identical to WIX P/N 49946 and Napa P/N FIL9946. Printed on the filter it states that it has a dust capacity of 540g, max air flow rate = 675 cfm, max pressure drop = 0.36 psi. It has 42 "pleats" and they are 3.75" tall. Efficiency is 99.6%. Cost is approx $26, but may be as high as $33.
53032700AA (Previous Dodge air filter) identical to Fleetguard AF26106: Printed on the filter it states that it has a dust capacity of 450g, max air flow rate = 675 cfm, max pressure drop = 0.51 psi. It has 88 "pleats" and they are 1.75" tall with a 7/16" thick foam pad glued onto the bottom. Efficiency is 99.5%. Cost is approx $21.
Amsoil EaA189: (Nanofiber stock filter): Has 46 "pleats" that are 1.75" tall. Filter media feels like paper. According to PSM website, has dust capacity of 39 grams. Efficiency is 98.3%. Cost is approx $36-50.
aFe 30-10102: (Pro-Guard 5): Has 22 "pleats" that are 1.25" tall. This is an oiled filter. Don't know the dust holding capacity, but this is the old oiled filter from aFe with lower efficiency. Efficiency less than 99%. Cost is approx $70.
aFe 73-10102: (Pro-Guard 7): Has 22 "pleats" that are 1.25" tall. This is their newer oiled filter. According to PSM website, has dust capacity of 233 grams. Efficiency is 99.2%. Cost is approx $85.
AEM 28-20776DK: (Dryflow): Don't know the pleat count or the size, but is very close to the aFe filters. According to PSM website, has dust capacity of 74 grams. Efficiency is 99.4%. Cost is approx $75.
Old Nov 27, 2010 | 10:50 PM
Blacksunshine's Avatar
good test but seems a little stacked, duramax and ac delco. arent they in the same company
wheatwhacker
Mar 25, 2012 06:20 PM
ManOfSteel
Apr 20, 2011 07:05 PM
caburnside
Nov 6, 2008 04:52 AM
tontof18
Sep 14, 2006 11:57 PM
