6.7l REALLY THAT BAD?
Man if you can work on jet engines your good to go...
Delete the DPF and EGR is no more mechanically challenging than say, doing a brake job. Installing the Smarty is a matter of plugging into the OBDII port and following the on screen instructions.
Take your time and read some, there are many many post about the deletes on here, lots of good info.
Not to mention if you have any other questions, just ask, lot of good folks on here more than happy to help.
Yes, the egr block off and dpf adjustment are not difficult. Its much easier if you have an assistant to help remove the dpf but if no help is around a jack stand works well also.
Beer helps also.
Beer helps also.
sqrl$$
May 21, 2011 11:15 AM
SconsinSmoker
Feb 19, 2008 11:22 PM
hubmonkey
33
Mar 3, 2007 02:59 PM
