6.7l boost pressure
Old Jul 26, 2007 | 11:13 AM
caper11's Avatar
6.7l boost pressure
Does anybody know what the 6.7 develops for boost on a stock engine?
Old Jul 26, 2007 | 11:24 AM
MtnTrucker's Avatar
I just got my Commander gauges working last week. Highest I've seen so far towing a 5K boat going up a pretty long and steep hill on the highway is 24 lbs of boost. And that was only for a very brief period.
Old Jul 26, 2007 | 11:55 AM
MikeyB's Avatar
I thought the 6.7 would spike into the mid 30's and then settle down to the mid 20's?
Still haven't installed the 50psi gauge on my Dad's truck yet so I won't actually know until it's done.
MikeyB
Old Jul 26, 2007 | 12:35 PM
MtnTrucker's Avatar
MikeyB-That could be the case. To be honest, it was pulling so good I was flying most of the time (75 mph going up a 6% grade) and not working it that hard. I saw the boost go to 24 lbs one time when some goof pulled out in front of me and I lost my momentum, mashed the go pedal and it down shifted from 6 to 5. We got right back to 75 mph pretty quick and the boost sttled down into the 10-20 range.
Old Jul 26, 2007 | 12:53 PM
KMKDiesel's Avatar
Before I strait piped it and started having problems I was topping off at 32 but the was not stock. Now its about 24 the highest
circlerangus's Avatar
If i remember right ive gotten 28 a couple times but that was really getting on it.
Old Jul 26, 2007 | 01:31 PM
gandrews's Avatar
While pulling a 5th wheel that weighs about 13900lbs - and put the pedal to the floor it will "spike" to almost 30lbs then settles in 22+ until I let off.
I have never seen over 30 and see 10lb+ regularly while towing on relatively level road.
Old Jul 26, 2007 | 07:02 PM
Jeb_H's Avatar
KMKDiesel,
You have a 6.7L that is straight piped??? If so, please tell me more???
Old Jul 26, 2007 | 09:13 PM
Ga_Mike's Avatar
I have a boost gauge on mine and i get max of 30 to 31...Hope this helps. When i tried to put a homemade ****** intake on mine all i could get was 22 and some hesitation. So stock box and filter went back on. Hope this helps.
Mike
Old Dec 11, 2007 | 07:18 PM
Ater installing a south bend double disk with my power pup loaded with a heavy load mine has spiked at 46 on some pretty good hills and will hold 40 pretty easy with a good load on a hill.
Old Dec 11, 2007 | 08:29 PM
KMKDiesel's Avatar
which clutch did you get I am thinking about getting the iron giant
Old Dec 12, 2007 | 09:40 AM
Im pretty sure it was the 2450 lbft one it wasnt the iron giant. Retail on it was 1700 but i got it for 1500.
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
