4:10 Gearing help
Old Apr 2, 2013 | 08:51 PM
mung's Avatar
Cool 4:10 Gearing help
Looking at purchasing new truck has everything I want the only downfall for me is the 4:10 gears. Is there a advantage or disadvantage. I only drive it on the wk ends Would like to get good fuel mileage Is it possible Thanks
Old Apr 2, 2013 | 09:29 PM
whiteeye42's Avatar
4:10 gears will hurt your fuel mileage only good thing is you will be able to pull heavier loads
Old Apr 2, 2013 | 10:09 PM
Tim M's Avatar
Another advantage is you can run larger tires. For example it works out roughly that a 35" tire with a 4:10 is about the same final drive as stock 265's with a 3:73.
http://www.rimsntires.com/specs.jsp
snowjoker
Jan 23, 2010 06:16 AM
BUZZB8Z
May 8, 2005 08:59 AM
faurotus
Apr 5, 2003 10:49 PM
malibu
Feb 18, 2003 07:21 AM
