4.10 available with G56
yes they are. 4.10 are available with the g56. Some time in o7 they changed ratios in the g56 ( so i understand.) And in my search for a 08 truck I ran across a bunch of 3500 with the g56 and 4.10,s. I think theres even one or two on ebay.
You should have 3.73 if there was no paper work. It would be listed under standard equipment for a certain package or in the options list under antispin. I dodnt think until 08 you could get 410 with g56 unless you had a cab/chassis 2500/3500
that is my understanding as well only in c/c maodels and I could not imagine even with the new ratio having 4.10s unless you were running 37s or larger simply not necessary
http://www.yotatech.com/~corey/tire_calc/tt_offroad.htm
4:10's with 35" tires would have me back close to stock @ 3:63 ratio.
3:73's with 35" right now would give me effectively a 3:30
3:73's with my current 33" now has me @ 3:50
I plugged in approx tire diameter sizes 33 instead of 32.7 etc, close enough.. I've already got the top end rpms problem solved but there's no way I would run 35 tires without 4:10 gears.
berner
Dec 31, 2002 01:04 PM
