yet another oil change question
Old Aug 26, 2005 | 09:57 PM
hemimaniac's Avatar
At my last oil change.....when I loosened the filter, I had no oil running out of the top and down the filter,,,,puzzled,, I then took it off and noticed that it was only 1/2 to3/4 full with oil !!!!! is this normal ??? should I be concerned:
Old Aug 26, 2005 | 10:32 PM
peacemaker's Avatar
Mine has been the 4 times I've changed it.
Old Aug 26, 2005 | 10:43 PM
Stingerpup's Avatar
It depends on how long you have let it sit after turning it off. In my Y2K, if I let it sit for a few hours, the system would suck oil out of the filter, leaving it about 1/2 to 3/4 full.
If I went to change the oil right after I turned it off, it was full.
Old Aug 26, 2005 | 10:54 PM
J BODY's Avatar
Here's what I find at work. The Mopar filters make a mess when I remove them (and Fleetguard). The orange ones, the yellow ones, NAPA, and wix will usually come off and be 3/4 to 1/2 full. Makes my life a little easier.
Old Aug 27, 2005 | 11:10 PM
drew03's Avatar
each time i change mine it is a little cleaner. practice makes perfect.
Old Aug 29, 2005 | 12:48 PM
jlbrown's Avatar
Try using a gallon zip lock bag like under the "Tech Facts/General Info". Works like a charm.
Old Aug 29, 2005 | 09:51 PM
JAF's Avatar
JAF
Mine is the same. 185,000 - still running. Think any issue would have manifested by now.
coastal_diesel
May 4, 2009 05:38 PM
jiMMyCTD
Mar 15, 2007 09:00 AM
gman07
Aug 30, 2005 11:08 PM
yrusoslow2
Sep 26, 2003 11:08 AM
twhite
13
May 15, 2003 01:03 PM
