winter idle
Old Feb 23, 2010 | 01:20 PM
michael/edge's Avatar
winter idle
i was wandering how your trucks idle during the winter. when its cold out when i start my truck it wraps up to 1000 rpm and idles like that until i go to drive. or if it is a little warmer it idles normal then in a couple of minutes it wraps up 1000 grand.
my dads 03 his will always idle normal no matter how cold it is. then after a few mminutes his will wrap to a grand then after a couple of minutes it goes to normal and cycles like this until he drives.
since both are trucks are 03 how come they idle differnt. how should they idle..how does yours idle....
Old Feb 23, 2010 | 02:29 PM
riddle family's Avatar
Mine does what your's does. But it only jumps up quick if it is below 20 degrees. If it is better than 20 usually a normal idle then a jump to a 1000 rpm.
Old Feb 23, 2010 | 03:06 PM
billie's Avatar
My 03 will do idle both ways depending on temp. PLugged in it will idle up in a minute or so and not plugged in it will idle up on start. Maybe your straight pipe is not holding quite as much heat under the hood compared to your Dad's? Every truck will be a bit different.
Old Feb 23, 2010 | 07:33 PM
NickBeek's Avatar
Your truck is doing what mine does, so I would say it is normal operation. Maybe your truck got flashed with a later calibration? Maybe your truck was built after your fathers and has a later calibration?
Tedonlin150
46
Nov 21, 2011 10:45 AM
HOHN
Dec 29, 2007 09:39 AM
carwash
Nov 24, 2007 08:04 PM
Common
Oct 20, 2006 08:28 AM
jj3500
Dec 25, 2005 11:02 PM
