Wind noise
Do any of you guys get wind noise from the mirrors'? Seems like i get a whistle from the mirrors'. I dont know but it gets old
Looking for a fix has anybody had this before? Thanks J,C,
Mine sounds like it is coming from the windows or doors. I had checked all the windows and the doors were all closed. This was the 1st time that I really noticed it. Haven't been on the interstate since to see if it is still doing it. I notice it at about 70-75.
Might be worth looking at,
Right were your door meets the front fender,right behind the hinges going toward the front of the truck they have some kind of foam thingy I guess for wind noise and draft,mine is just there no glue or anything maybe yours is falling off or is missing.
See if my picts show up here.
http://i229.photobucket.com/albums/e...ruck001002.jpg
http://i229.photobucket.com/albums/e...ruck001001.jpg
It sounds likwe the morror but it is actually your door seal leaking cuz the door over time has warped out gently bend the top of the door (with the window down) back towards the cab...place a wood block close to the door latch...and the noise will stop
Wind Noise
Hi Guys,
My truck was making a lot of wind noise at 70 mph. I was getting really upset with it when I found the problem. If you have electric windows try this. On the driver side window just bump the window switch for down to let it take the pressure of the the top window seal. If you watch it when you roll it up and down it will move the window seal at the bottom and the top of the window. Play with the switch and you can stop a lot of the wind noise. I need to take it to the dealer to see if they can adjust how far the window rolls up. Good luck guys.
Its prob. your door gaskets thiers a tsb for this. I got this info from a guy on here few days ago, got them today for 12.75 each installed them both in under 10 min. and all is good. If your interested or think this is your prob. i'll get you the part numbers.
Slice
Mar 16, 2004 09:13 PM
CCOUGHRAN
15
Feb 27, 2004 01:38 PM
vernl
Oct 14, 2003 06:06 PM
