Will P01740 clear by itself?
Old Jan 19, 2012 | 03:30 PM
NJMurvin's Avatar
I got a CEL today and my codes are P0191, P0514 and P1740. I have had the P0191 and P0514 before and they were benign (in fact, I think there's a TSB out there for this). In about a week the CEL went off by itself. But, I've never had the P1740 before - something about an overdrive solenoid. I have a short commute, so I've been driving my truck with the OD turned off (T/H). So, it never even tried to go into OD this morning. Anyway, I had the trans serviced about 2500 miles ago and it shifts just fine.
It threw the codes this morning (pretty cold for SoCal ~40). My batteries are original and are likely due to be replaced (7+ years). I'm hoping that some electrical glitch due to failing batteries, grid heater and cold starting caused the codes.
Back to the original question: will the P1740 clear itself or do I have to get a reader and reset it?
Old Jan 19, 2012 | 07:58 PM
BigIron70's Avatar
Cummins Guru
P1740 indicates a malfunctioning torque convertor or TCC solenoid problem. You should have the TCC test done and the 3-4 shift test done.
Old Jan 20, 2012 | 11:11 AM
NJMurvin's Avatar
Are those tests that the dealer would do? I don't notice any change in shifting since I threw the code. TC lockup and shifting into OD work normally. I can't tell any difference. But, if there are tests that can be done to see if something is failing, I'm definitely interested.
Old Jan 20, 2012 | 07:53 PM
06RAM2500's Avatar
Originally Posted by bigiron70
p1740 indicates a malfunctioning torque convertor or tcc solenoid problem. You should have the tcc test done and the 3-4 shift test done.
engine dtcs present
transmission dtcs present
transmission temperature too cold
oil pan contains excessive debris
3-4 shift solenoid
shaft or seal damage
tcc solenoid
torque converter
Old Jan 20, 2012 | 08:17 PM
Colo_River_Ram's Avatar
With age comes the cage
You can clear/reset the codes in the same manner you read them by turning the key off on the 3rd cycle..(vs leaving it on for the codes) If the code re-appears then have it checked out.
Old Jan 22, 2012 | 01:28 PM
NJMurvin's Avatar
Well, the CEL went off by itself. The codes are still in there (when I read them). I will try the method above to clear them. Because the trans seems to work perfectly, I will clear the codes and see if it recurs. If so, I will definitely get it checked out.
Old Jan 23, 2012 | 06:13 PM
NJMurvin's Avatar
I tried this and they don't clear. Am I doing something wrong? On/Off/On/Off/On/Off. Wait a few seconds, then check ... codes still there.
Old Jan 23, 2012 | 07:37 PM
06RAM2500's Avatar
They key trick doesn't clear them, it only lets you know if any codes are present.
If there aren't any, all you'll get is ------
If there are codes, it'll be P-----, C-----, or U----- then it'll display --DONE--
You'll have to write them down pretty fast, otherwise your gonna have to start the whole thing over.
Old Jan 24, 2012 | 05:23 PM
NJMurvin's Avatar
That's what I thought. But, the post above suggests that you can clear them too. I guess I need to get my hands on a Smarty Jr.
Old Jan 24, 2012 | 08:56 PM
The key trick has cleared them for me. If the fault was still present the code son reappeared.
jlarmour
Nov 26, 2006 01:02 AM
lifer
Apr 2, 2004 09:23 PM
jigdog
Mar 12, 2004 01:27 AM
quantrill88
Dec 13, 2003 01:01 PM
HOHN
Oct 9, 2003 06:22 PM
