White smoke...now no start
Old Mar 6, 2006 | 09:57 PM
AggieJustin's Avatar
Exclamation White smoke...now no start
This is for a friend of mine. '04 3500 DRW 6-speed 4x4 (305/555). Bought it used with about 19K on it, now it's got around 85K. Been running an Edge EZ for about 50K.
For a little while, he's been noticing just a slight white haze from the tail pipe at idle. Kinda like a gasser at idle on a cold day, but no where near as thick. A couple of weeks back while towing his 36' flatbed loaded with hay, he said it started smoking white pretty heavily. Wasn't running any different, just pouring white smoke from the tailpipe. Pulled over and checked the major things underhood and didn't see anything, so he limped it along the shoulder till he got closer to home. When he got closer, he went back to driving normal and didn't have any other issues with it. Took it in to the dealer when he got home, but they didn't find anything on it. I'm thinking they just hooked it up to the computer to pull codes, but there weren't any. They didn't have the truck long enough to do any in-depth tests.
Fast forward to present...was pulling his trailer again and slowing down to turn into a driveway. Just as it reached idle when he hit the clutch, it died on him. Started it and it fired right back up, but died right away. Did this two more times, then wouldn't start at all. Turned the key off totally, waited a second, then tried again. It fired right off and ran fine. Later on as he was waiting for a traffic light (in the middle of town no less), it died again. He was able to restart it, but it would die if you touched the accelerator. Then it just wouldn't start at all. Says it's turning over just fine (actually said it sounded a little fast), but it won't fire up.
Anyone seen/heard of this before or might have a preliminary diagnosis? It's at the dealer right now, but he wants to have some backup for when he talks to the service tech. This is the same place it was taken before when they said everything was just fine. They said "Well, I guess we'll be able to figure out what's wrong this time since it's not running". Not confidence inspiring.
Any ideas anyone might have, let me know and I'll pass them along.
Old Mar 7, 2006 | 01:38 AM
TexasCTD's Avatar
Another guy on here recently had his truck die on him too. He had gone 25,000 miles on the fuel filter. He replaced it and problem solved.
I would start there. Hope that helps.
Old Mar 7, 2006 | 12:27 PM
Filter was cleaned. I drilled into him with his first truck to make sure to change out fuel filters regularly and keep some spares on hand. In this case, it turned out to be a dead lift pump. Which makes sense on the no start issue because it couldn't get any fuel. But would the lift pump cause the white smoke issues that he's been having?
I've been searching on here and most of the white smoke issues were just at startup (usually accompanied by running rough). But he hasn't had that, just a slight white haze at idle and the one episode of huge clouds while driving. My concern is that there is still another issue there that's not being addressed and he doesn't have that much further to go on warranty.
So DC is fitting his truck with the new in-tank pump right now (warranty replacement), so I guess we'll see how this goes. Has anyone found a solution to the low pressure issues with the in-tank pump? Does this new pump have enough flow to support a big line kit to make sure enough fuel is getting to the pump?
Old Mar 13, 2006 | 11:17 PM
guide_master's Avatar
Exclamation fuel pump
fuel pump in tank is volume not pressure,I have an 04.5 notting but problems, first week i had it changed out # 4 injector and transfer pump , good for about a year. changed lift pump to fuel tank one and changed # 4 injector again,drove 2 hours truck start to smokke black and want to run away on me,drive to more hours drive in to dealerput on scanner . they turn truck of .not starting changed injectors #5&6/drive 2 more hour on my way home , stop truck ,will not start ,tow truck to dealer.changed to sencers on my way home truck start smoking again and wanting to run away,and i,m talking holding the brakes hard at a stop sign and smoke pooring out like i was pulling train behind the truck take it to dealer again , 16 hour labour all they found is more bad injectors,going on a 2hour drive tomorow hope i make it back but it already starting to act up.and i also have the shaking stearing now so I MUST HAVE A GOOD ONE OR WHAT
Old Mar 13, 2006 | 11:22 PM
33000 km on the truck
recone5
Nov 5, 2008 10:26 AM
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
dhe9
Nov 14, 2003 07:31 AM
