white smoke
Old Mar 24, 2007 | 08:09 PM
BuildingBoost's Avatar
white smoke
Last Friday my truck did something I have never seen her do before. After the truck had been sitting for a couple hours, I went to start it and had a good amount of white smoke billow out of the exhaust while in park. After a watching if for a day, here is how the smoke plays out:
1. Start up = White smoke
2. Idol in park = fairly clear
3. Idol in drive = occasionally random puffs of noticeable white smoke.
4. Acceleration = Mix white and black smoke
5. Revving the engine in park = Mix of smoke, almost looks brown
You can see what I have in my sig…any suggestions?
Thanks in advance for the insight.
Old Mar 25, 2007 | 09:03 AM
cattledogzip's Avatar
Have the air intake temp. sensor checked. White smoke is usually the cause of a lean fuel condition.
Old Mar 25, 2007 | 01:39 PM
Smkndzl's Avatar
It is not a lean fuel conditon , it is wet hydrocarbon either from not enough heat to burn the fuel during the firing stroke or timing of the injection of fuel issue.
Old Mar 25, 2007 | 06:14 PM
Best way to correct
If this is a timing issue, is that any easy fix. What about a leaky injector?
Old Mar 25, 2007 | 09:54 PM
Smkndzl's Avatar
It could be a leaking injector, I would run some fuel additives thru it.
Old Mar 27, 2007 | 12:22 AM
Mixer Man's Avatar
Take that baby in to the dealer ........... many had those early symptoms of fuel leaking past injectors when it sat and ended up with bad ones . Not trying to freak you out but keep an eye on it .
recone5
Nov 5, 2008 10:26 AM
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
dhe9
Nov 14, 2003 07:31 AM
