Wheel Hop
Old Nov 23, 2011 | 06:57 AM
Berny's Avatar
Wheel Hop
Hi Fellow Dodge owners. New to the Forum. On a recent trip to Wyoming from Calif. found I developed a Wheel Hop at 70 mph. Feels like it's in the rear. Replaced shocks (pretty soft) didn't solve the problem. Truck has 60 k miles and have not had one problem other than this one. Been hearing there may be a campeign for a recall???? Any suggestions out there??
Old Nov 23, 2011 | 08:08 AM
verdesardog's Avatar
sounds like a bad tire to me......
Old Nov 23, 2011 | 12:07 PM
.boB's Avatar
Wheel hop generally means when you accelerate briskly from a stop, one or both of the rear wheels actually hop up and down.
Is this what you have?
Old Nov 23, 2011 | 12:54 PM
Berny's Avatar
No, what I have is the wheel hop at high speeds (70 t0 75) going over rough spots on the highway.
Old Nov 23, 2011 | 01:24 PM
steelblitzkrieg's Avatar
DTR Detective
My guess is you're experiencing the rhythmic bounce of a concrete highway which is normal, slow down or speed up and it goes away? If so, it's normal.
The trucks length allows it to get into a harmonic-like pattern of bouncing when crossing the concrete slab gaps at certain speeds.
Old Nov 23, 2011 | 04:15 PM
Berny's Avatar
Hi Guys,
This is not pavement or harmonics, This is the entire rear leafs and axel bouncing up and down violently to where I must slow down and then it stops. What starts it is a succession of rough pavement enough to get it going. once slowed to 60 it stops. The length of rough pavement can be as little as ten feet. I just need to be doing 70 plus. This wheel hop continues after the rough pavement until I slow down.
Old Nov 23, 2011 | 05:04 PM
DTR Detective
Bad leaf? Loose shackle? Don't know what else it could be if it's as violent as you describe.
Do you feel it in the steering? Death Wobble?
Old Nov 24, 2011 | 11:37 AM
Berny's Avatar
Wheel Hop
Thanks for all the input. Responding to to last question....I am not experiencing "Death Wobble" it's only in the rear. I Decided to take it to the "Dealer" After $135.00 found nothing wrong except for throwing a two ounce weight and some minor tire preasure problems. They checked out the Leaf Springs and found nothing, Did all the calculations re: measurements from front to rear to see if the diff was out of allignment with the front and tranny. All was ok. On our way out to thanksgiving dinner on a wet road. Wish me luck. If it happens today and I don't get back to you......Look for me in the Obits.
Old Nov 25, 2011 | 08:35 PM
Luther Douglas's Avatar
From the problem you described you have a tire out of round , the way to determine this put the tire on a balance machine and watch the top or bottom of the tire
Old Nov 27, 2011 | 11:01 AM
Foxborough's Avatar
I believe it's your tires. A the long time ago we had a van with the same problem. Nothing else worked and finally some "good old boy" mechanic smiled and told me to get new tires.
The sidewalls may be shot and they bounce like basketballs. You could have someone follow behind and watch, good luck.
Old Nov 27, 2011 | 12:37 PM
ubet's Avatar
In a 2001 f250 powerstroke, the ranch I work for owns, I was going down the road and for 100 miles or so, I was going through what you described. You know what fixed it, the tire blew, I changed tires, no more bounce. My guess is one of your tires is about to blow.
Old Nov 28, 2011 | 01:56 PM
DodgeChallenger's Avatar
Yes I agree! the tire has most likely got a failure point on the tread that is bulging out. Very dangerous if it has.
Robert P
20
Mar 25, 2006 02:47 PM
Backwoods
13
Feb 15, 2006 08:00 PM
imdok
Jun 7, 2005 10:13 AM
Tank_66
Jan 2, 2005 07:24 PM
