Wheel Bearing (hub) greasable thru ABS fastener hole?
Old Aug 14, 2009 | 02:39 PM
steve05ram360's Avatar
here is a good shot of the sensor area...
I talked with a guy who actually pulled the bearing assembly apart and repacked it. He took many pics and I tried to get him to do a writeup but he was short on free time...
Old Aug 14, 2009 | 04:06 PM
Blueboy's Avatar
I just packed mine when I replaced rotors.
3/16 allen wrench to pull censer. I used the
end of allen wrench to pack bearing.
Old Aug 14, 2009 | 10:14 PM
Sniper05's Avatar
I used a surenge, i hope i spelled that right, i packed it with grease, then had my buddy spin the hub while i injected the grease, did that twice, it really works well except the part where i broke my ABS sensor removing it, its really not that hard to do just a little time consuming, but well worth since it could yeild alot more time the stockers will last, and at $250+ a peice its kinda worth it!
Old Aug 14, 2009 | 10:24 PM
annabelle's Avatar
I have 247,000 on mine and never tried greasing them.....I don't think you can get ant grease in the bearing with this method.
Old Aug 15, 2009 | 11:50 AM
1985cucv's Avatar
should i do this on my new rotors? i have like 3000 miles on them and am going to be doing ball joints, and the upgraded steering while im in there i might as well grease them right? oh and if you do this and take everything apart use anti seize it is great!
Old Aug 15, 2009 | 12:19 PM
thames1948's Avatar
Isn't it a sealed bearing ? Sealed bearings that I have seen have a rubber cover to keep the grease in. I would think you would have to punture that to get grease in. Maybe I'm wrong.
Old Aug 15, 2009 | 09:37 PM
800rmk's Avatar
Subscribing, interesting!!
Old Aug 15, 2009 | 11:52 PM
billie's Avatar
The ABS provides access to the sealed bearing. Not the same as packing regular bearings but it seems to extend the life so for a squirt or so, why not.
Old Aug 16, 2009 | 08:44 AM
JP-4.5's Avatar
To bad there is not a long grease fitting that could be used to hold ABS sensor and allow grease to be pumped in. Would be nice!
Old Aug 16, 2009 | 08:49 AM
billie's Avatar
But it wouldn't generate much in replacement part sales
Old Aug 16, 2009 | 09:55 AM
Raspy's Avatar
Does anyone have pictures of a hub taken apart? I threw mine out when I put the free-spin setup on and now I'm curious about this "sealed" bearing question. Are the bearings themselves sealed or are they in a closed case that can simply have grease added?
Old Aug 16, 2009 | 10:01 AM
Blueboy's Avatar
When you pull ABS censer, turn hub and you can see bearing turn.
there is no covering over bearing other then censer.
Old Aug 16, 2009 | 04:07 PM
Highway 4x4's Avatar
So what is the best kind of grease to use. Mobile 1 syn? I have herd that it can be bad to mix oil. Would be funny to wipe out a bearing trying to save it.
Old Aug 16, 2009 | 04:13 PM
JP-4.5's Avatar
Would not be funny to me...
I have also heard some of the synthetics get to watery and run right out..
What type of lube have been used with good success?
Old Aug 16, 2009 | 06:34 PM
gadget.35-06's Avatar
Clarify, prease: This works for both 2WD and 4WD?
