Wheel Bearing (hub) greasable thru ABS fastener hole?
Awhile back I read on here that you could grease the unit bearings through the fastener hole that holds the ABS sensor on. I'm not sure if the person was talking 3rd gen or 2nd gen though. Anyone tried it on a 3rd gen?
I've got mine apart right now replacing a u-joint on the front axle and I thought I'd give it a try if it won't hurt anything. Worried about it messing up the wheel speed sensor though.
Thanks guys, I'll give it a shot (no pun intended).
Oh...almost forgot. Do you bother installing a zerk in the fastener hole or just shoot it straight from the grease gun?
Got-er-done. The ABS sensor fastener hole is blind, so I had to shoot it through the sensor hole. Use a needle fitting to get the grease down inside, otherwise it tried to spooge out the same way it came in because there is no way for the air to get out.
Thanks again guys.
Thanks again guys.
Ok I am confused...as far as I know the front bearings are a sealed unit design which would mean the ABS sensor operates off a tone wheel or magnetic ring that is integrated with the sealed unit? I have never seen a sealed bearing that can be greased externally without removing and separating the bearing...I am going to check the manual but to me it doesn't make sense that you can get grease intot he bearing through the ABS sensor?
Ok looking in the manual it appears the ABS sensor is mounted into the Hub/bearing unit and not mounted onto the knuckle like most cars...so I guess it may be possible to remove sensor and jam grease in there. My next question would then be the risk of introducing dirt/contamination from removing the sensor and putting a grease needle into a hole that is blind. Contamination may be worse than not doing anything....Sealed bearing units are generally fairly reliable. Are they problematic on our trucks? I haven't heard of too many abnormal failures on this site but I may be wrong. If there are a large number of failures then it may be wise to remove the hub/bearing all together, disassemble, flush out all old grease and use a quality synthetic grease to pack it new and reassemble (yes I know it's a sealed bearing, but even then they can sometimes be gently disassembled and packed....somethimes).
For the first 25k miles or so
Mine first went at about 40k and now I'm at 94k and no issues yet. Some have recorded no replacement to 200k+ so it seems to work. As to contamination, clean grease won't cause a problem with magnatism. Dirt would be bad so keep it clean...no problem.
I think those bearings get hot from the brakes and eventually drys out the grease leading to premature failure and they aren't cheap, or under warranty.
I repack sealed ujoints when they're new too. The last one I bought was very sparse for factory grease.
You have to remove the sensor anyway to work on anything other than the brakes, so contamination risk is based on how clean you keep during disassembly, reassembly, and in-between.
Oh, and a clarification- you don't shoot the grease into the blind fastener hole (blind holes don't go nowhere). You shoot it in through the sensor hole, which is a thru hole.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
knock on wood I have over 80k on mine with zero failures. I am just now needing or at least wanting to replace the steering to the upgraded. Ball joints still check out fine. oh and over 80k with 37" or bigger tires since the truck had 33 miles on it.
