whats minimum thickness on front brake pads?
mine are under 1/4 and squealing at light pedal pressure. Ive got about 60K on them, but live at the bottom of a decent hill, so I would suspect possibly needing replacement. I havent torn them apart to look, just looked at the pads while rotating tires the other day
I have not torn one of these down yet, but do ours have the little metal "Squealers" on them? That might be what you are hearing. If so, it is time to change.
I would guess 1/4" is probably about the thickness the squealers would start.
Shop said my fronts were at 3mm when I had an alignment (75k mi). They were not squealing yet.
Quick easy change out if your rotors aren't warped.
I scuffed the rotors with some 220grit real good like always since they didn't need to be turned and weren't really worn.
Make sure you watch the brake fluid level when squeezing the calipers back in so you don;t overflow the reservior if any fluid has been added.
Diesel_Power_2
Dec 7, 2012 10:02 AM
CZSteve
Feb 18, 2011 01:07 PM
schamran
Nov 22, 2010 07:08 AM
Chip
14
Jun 21, 2009 03:59 AM
steelblitzkrieg
Jul 5, 2008 02:38 AM
