whats this leaking?? tried to post pics :(
Old Apr 3, 2005 | 09:39 PM
HorseHauler's Avatar
whats this leaking?? *PICS*
I've noticed some leaking around my valve cover. Is this somthing to be concerened about? Here are some pics, finally worked
Thanks
Eric
Old Apr 3, 2005 | 10:21 PM
I think pics might work... lets see
Old Apr 3, 2005 | 10:23 PM
YAY
still ticked about the leak
Old Apr 4, 2005 | 12:00 AM
Hemi Cat's Avatar
Looks like a valve cover gasket seeping. Check the bolt torques, if ok, replace the gaskets. Sometimes just loosening it and repositioning it then retorque it will cure the annoying seepage.
Old Apr 4, 2005 | 06:40 AM
handymantim's Avatar
That valve cover gasket is a reusable neoprene model.
If it were me, I'd spray it down with engine degreaser, hose it off and then wait to see how long it takes to get oily again. If it even does.
Old Apr 4, 2005 | 09:10 AM
thanks fellas for the replys. I'll have to try that. I hate to spray water around my engine cause it always gets corrosion and crap around bolts and stuff
i've been wanting to clean my engine so ill go ahead and do it. any thing i need to know on what to keep water and degreaser away from?
Old Apr 4, 2005 | 04:38 PM
PourinDiesel's Avatar
Just remove your vanity and valve covers.
There are I think 7 bolts that are 10mm that hold the rocker box down and they torque to 24nm/18ft lbs., that should cure your issue.
The top 2 covers are also torque to that same spec.
Old Apr 4, 2005 | 07:44 PM
Hounddog's Avatar
Its warranty for 7/100.Its a seepage and most if not all seem to be doing this.
Old Apr 5, 2005 | 09:55 AM
Agades's Avatar
got the same thing
cause I spill oil every time I change oil
seaps through the plastic cover around the filler neck and seaps down around the head
Old Apr 5, 2005 | 07:30 PM
Hounddog's Avatar
It ain't from spilling oil.Some extra on yours might be.But thats were there ozzing from.Mine has not had oil spilled.I've cleaned it twice in 15k and its back!
Old Apr 5, 2005 | 10:59 PM
Mark Thomas's Avatar
Looks like a bit of coolant seepage from the plugs, might want to have that looked at as well. Mine had that when it was new.
Old Apr 6, 2005 | 08:07 AM
Agades's Avatar
yah
I guess mine is more to the front of the motor
and not quite that thick
Old Apr 6, 2005 | 06:18 PM
DSLRammin's Avatar
I have the same thing here
Old Apr 6, 2005 | 08:15 PM
Hounddog's Avatar
I think lots if not all are doing it.
Old Apr 6, 2005 | 10:21 PM
CTDinMT's Avatar
Mine looks the same. I just hate dealers so I have put off taking the truck in for any warantee work, but it's added to the list. That way, I can get everything done at one time. -Steve
