What is stock tire size on a 2004 ram 2500?
Old Mar 30, 2009 | 08:46 AM
sallyman1's Avatar
I want to get new tires and rims. i ordered the black/polished moto metal 957's 17by9 inch. I want to go a little bigger than stock but not much.does 285/70R17 sound right for about a stock size?
Old Mar 30, 2009 | 08:56 AM
lniemeyer2's Avatar
265/70 R17 for the stock size.
Old Mar 30, 2009 | 09:05 AM
STate's Avatar
I agree, so if you want to go a little bigger the 285 70 17 should be just right.
Old Mar 30, 2009 | 09:24 AM
sallyman1's Avatar
thats what i thought thanks. i wanna go with BFG all terrains 8 ply. can a person get 10 ply bfg all terrains? dealer says i cant.
Old Mar 30, 2009 | 11:17 AM
Bowser50's Avatar
I got 305 70 17's on there and now I have 315 70 R17's on there with hummer h2 wheels looks and rides good.
Old Mar 30, 2009 | 01:35 PM
Raspy's Avatar
You can't get any of them in either 8 or 10 ply. They are D or E rated, but not 8 or 10 ply. Read the side of the tire to satisfy yourself on this.
Old Mar 30, 2009 | 01:45 PM
troll3193's Avatar
I have E-rated ten ply BFG all terrain KO's they are the stock size 265/70 R17
here is the size chart..
http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
they make a LT285/70R17/E
Bryan
Old Mar 30, 2009 | 04:17 PM
Raspy's Avatar
They may be E rated, but read the sidewall before you decide they are ten ply.
Old Mar 30, 2009 | 04:23 PM
annabelle's Avatar
BFG just came out with an E rated 285.....I have no idea of the plys.
Old Mar 30, 2009 | 06:01 PM
Dodgezilla's Avatar
The D-Rated 285 BFGs work just fine. I had them on my 03 and I have a new set waiting to go on my current truck as soon as I have time to get it done...
Old Mar 30, 2009 | 06:15 PM
Raspy's Avatar
I had D rated BFG 285s on mine too. Liked the traction. But one unexpectedly blew out on the highway after a minor cut in the sidewall. Not a cut that got into the cord, just a little slice in the rubber and that's where it blew out.
In other words, they rely on the rubber for sidewall strength. Very, very weak in the sidewall, but also soft riding, if that's what you want.
Real trucks need real tires that are tough, unless you just want to putt around town and pick up groceries.
So after two sets of BFGs in 315 D and 285 D I went with Toyo 285/75 E and discovered a real truck tire. A little rougher ride, but they can handle anything the Dodge can. One interesting note is that they do the same job at significantly lower pressure. It's all about sidewall stiffness.
Old Mar 30, 2009 | 06:18 PM
annabelle's Avatar
Sam's and Discount Tire refused to install D rated tires on my 1 ton. I have E rated 265's. I wanted to go to 285.
Old Mar 31, 2009 | 12:52 AM
Highway 4x4's Avatar
I have the 265's now and want to be going 285's soon. I tow about 7500 lbs in the Rocky Mts. Will I notice any difference in tire size and up hill torque? 3.73gears and 48re.
Old Mar 31, 2009 | 03:11 AM
Raspy's Avatar
There will be a small difference in torque. You can correct the speedometer by adjusting the pinion factor at the dealership or by getting a Smarty.
Old Mar 31, 2009 | 07:00 AM
troll3193's Avatar
sorry I stand corrected, while they do make an e-rated in both sizes mentioned it does not say on the website, nor on the side of my tires that they are ten ply...
Bryan
