what problems if any on 05 3500 six speed
1. How many miles can I get out of the clutch w/ avg. driving?
2. Any problems that I should watch out for w/ this truck?
3. How would I find out what gears I have in my 3500?
It depends on which transmission you have. The NV5600 or G56. The G56 only comes with 3.73's and the NV5600 could have 3.73 or 4.10's. What is the build date on the truck? Manual transmission changed mid year to the G56 from what i have read.
Ball joints and the bearings up front are crap. You may want to look into the kit from Dynatrack when your bearings go out up front.
Also, AC problems.....Defrost door will break. And there is a rumoe around about injectors on teh 03's going bad. Mine have 150k HARD miles, and no prob's yet on them.
Never mind about injectors, you have an 05
I had problems with my clutch not releasing properly from the start, it took 2 trips to the shop (warranty) to fix it, 1st trip they replaced the flywheel do to an imbalance problem. 2nd they replaced the master/slave cylinder which was the problem all along.
A Jake E-Brake is in the future as I pull some heavy goose necks every now and then. Love the truck I get 19-20 hwy MT now and 13-15 depending on the trailer load.
PITBULL
Jan 20, 2005 09:18 PM
