What oil goes into Transfer case? ATF or Gear?
ATF+4 is what is spec....I've used Royal Purple Synchromax, but it's just too expensive. So I went back to ATF+4.
If you wanted, I'm sure you could run any of the manual transmission lubes as well, but they are not spec for the T-Case.
i guess if you stick your finger in and pull it out and it is red, it is atf. if it smells like crap and is dark in color it be gear erl.
MINE DON'T LEAK EITHER
