What kind of fuel mileage
Depends on the traffic.
Me, 6 miles at freeway speed (65-70mph) and 18 miles between stop and go and 25-30mph
8000 miles on it, Auto with 3:73, I got 15.1 last week.
Went to Monterey a month or so ago and got 18.1 (IIRC) overall, 350-400 miles round trip, took the Valley down and the Mountains back.
Labor day I went to Reno 400-450 round trip, 3-3.5hrs each way (normally), it took me 7hrs to get there due to holiday traffic and accidents, trip home went smooth, I averaged 14.3 or so.
Steel is right on the money. I'm about 14-15 MPG mixed driving, at very best scenario maybe 17-18, towing about 10-11 MPG. Im sure some will start chiming in though about getting low 20's or mid 20's with the same rigs. Kinda like fishing stories....
I have a 40 mile drive to work and am averaging 20.5 mpg. All stock everything so i trust my overhead should be right on the money. This is a 6 speed manual truck. I go through 9 traffic lights and never go above 55mph or whatever the posted speed limit is. You'll get less with an auto. Call it a fishing story if you want it's what I'm getting and I know of others doing the same. Some people say no two trucks are alike I tend to believe that more often than not its a case of someone thinking they know how to drive for mileage when really they dont.
Normally, I get 17 to 18 mpg (mostlt freeway 70+ mph) If I really baby it and try to keep it under 70mph, I get close to 20mpg. I'v noticed that I get my best mileage when the outside temperature is between 55deg and about 80deg F. Check out my sig for my mods.
i usually get 21 @ 60 mph this is a 630 mile round trip, and i make it on one tank, usually with 100 or so miles left too spare. The winter diesel has dropped me too 17-18. @65 i see closer too 17-18, and winter diesel it is 14
Maybe this could help you auto guys some. Someone verify that this is possible on the Ram. I used to do this in my 99 Durango. It would help with the mileage when puttering around town. I noticed that the torque converter would go into lock-up at 45 mph in O.D. One day I was messing around and turned the O.D. off and noticed that the torque converter would lock-up at 35 mph while in 3rd. So if I was going to be driving around town I would put the thing in 3rd to reduce the losses from the TC slippage. As soon as I got somewhere where the speed limit was above 40-45, I would turn the O.D. back on. Every little bit helps. My Ram is a 6spd so I am always in "lock-up" so to speak. Great mileage in town. Respectable mileage on the highway.
I was a non believer of the high mileage claims also. But if you keep it under 65 you can do very well. But a tow box also helps. My quad pushed me 1.5 right away. But you also have to consider other mods to better your fuel mileage. One is a cold air box. PLus if you run syn motor oil you will see another .5 per gallon on average. Plus a fuel addative. A stock 03 will do OK on fuel mileage. But if invest in a Edge EZ or Quad xzt an Airbox then go over to Rotella syn and Run FPPF you wil get better mileage. I just pulled off 22.1 with the auto in my sig. Keep in mind the tires have dropped my ratio to 3.90 and it was 97% highway. But it can be down if you can deal with setting the cruise at 60 and leaving it there.
