What front axle ujoint part #
Old Nov 13, 2008 | 10:48 AM
Sasqoutch's Avatar
Iv been doint some reading and it seems everyone has used different ones. I hear the percision 464 is the right one but some people say it dosent fit. So what did every one put in theirs? Doin ball joints soon so might as well do ujoints too.
Old Nov 13, 2008 | 11:39 AM
elirandolph's Avatar
precision 464 worked on mine.
Old Nov 14, 2008 | 06:44 AM
spitfire9137's Avatar
464 is the proper ujoint. Apparently there was a batch that had the wrong joint put into to a 464 box at percision and that was what was causing people problems. When you buy them open them up and make sure they are stamped 464 before you leave the store.
Old Nov 14, 2008 | 05:05 PM
saf-t scissors's Avatar
I posted this a couple of weeks ago, but it's worth repeating... I bought a Precision joint a while back. The store only had one in stock, so I went and got a 2nd joint from Carquest. The CQ joint was store-branded, $10-15 more expensive, but much better quality than the Precision joint. The casting was better finished, the seal design was better... it was overall a higher quality part.
If you've got a CQ nearby, I'd pick one up and compare.
Old Nov 14, 2008 | 10:10 PM
D45's Avatar
D45
How long are the stock front u-joints typically lasting for?
Are the aftermark u-joints coming with "proper" grease fittings or will they still take a needle fitting?
Old Nov 23, 2008 | 04:13 PM
notso's Avatar
Took mine to dealer said they were covered under warranty .Then they called to tell me they had to heat everythig up so they melted brake pads and warped rotors ?Ended up costing 500 for a warranty job!Now Im worried about bearings failing
ian515
Jul 24, 2009 03:22 PM
woodrep
Dec 31, 2007 08:48 AM
joeel
Apr 4, 2007 08:54 PM
joeel
Apr 4, 2007 08:27 PM
jaconst
Apr 7, 2006 10:45 PM
