what does this code mean???
Old Jan 17, 2010 | 09:34 AM
zx14on2's Avatar
po514: bat temperature sensor rationality. any idea what this means in english? thanks in advance
Old Jan 17, 2010 | 09:43 AM
madhat's Avatar
Administrator/Jarhead
Symptom:
P0514-BAT TEMPERATURE SENSOR RATIONALITY
When Monitored and Set Condition:
When Monitored: While the engine is running.
Set Condition: The ECM does not read a change in value from the sensor over time.
POSSIBLE CAUSES
BATTERY TEMP SENSOR
INTERMITTENT CONDITION
TEST ACTION APPLICABILITY
1 Remove the temperature sensor and reconnect the wiring harness connector to the
sensor.
Monitor DRBIIIt, while heating the sensor with an external heat source (DO NOT
USE OPEN FLAME).
Does the reading from the sensor increase at least 5 degrees F. on the DRBIIIt?
All
Yes ! Refer to the INTERMITTENT CONDITION Symptom (Diagnostic
Procedure).
Perform POWERTRAIN VERIFICATION TEST VER - 4 (DIESEL).
No ! Replace the battery temperature sensor.
Basically, it has not seen a change in temp over a certain period of time. Could be a bad connection or a bad sensor. You can take the sensor out and clean the contacts, see if that changes anything. If not, it could be the sensor.
Old Jan 17, 2010 | 09:59 AM
zx14on2's Avatar
Thanks!! where is this sensor located? do you have any pics? thanks!!!!
Old Jan 17, 2010 | 10:00 AM
madhat's Avatar
If you pull the battery off the tray, you should see the sensor... I'll try to look for a pic.
Old Jan 17, 2010 | 10:05 AM
zx14on2's Avatar
thanks..if no pic, thats cool. is it the battery by the air intake?
madhat's Avatar
Here is a pic of the tray, can't find the sensor off hand.
If you need more, let me know. Shoot me a PM...
Old Jan 17, 2010 | 10:06 AM
madhat's Avatar
I believe that they both have them.
Good time to clean the connections on the batteries, huh?
Old Jan 17, 2010 | 10:10 AM
zx14on2's Avatar
my friend hit some major snow drifts, and we think he might have plugged it good under there!! i will be warm, talking him through the pics with my phone.
Old Jan 17, 2010 | 10:52 AM
madhat's Avatar
Haha... loads of fun.
Get him to get on here later, let us know how it worked out.
WACTD
13
Aug 30, 2006 08:58 AM
dieselfan
Jul 28, 2006 07:25 PM
FDPOWER
Apr 13, 2006 11:45 AM
WalkerMike98
Jan 13, 2006 10:33 PM
salty mule
Mar 17, 2004 05:59 PM
