What do you think happened??? (A/C Issue)
Old May 12, 2009 | 01:18 PM
RCinMesa's Avatar
Last Friday, I started the truck, no A/C, pressed on the accelerator, still hot air. White smoke billowed out from under the hood with the smell of burned electrical wire (or slipping clutch - A/C compressor?).
Smoke went away, smell took longer. A/C worked fine after that. Yesterday it blew intermitently cold and somewhat cold.
Today it is at the dealer. They said connections, wires, charge and performance are all ok (A/C blowing at 38 degrees).
Anyone have a similar expereince or any ideas?
Old May 12, 2009 | 02:53 PM
cody459's Avatar
Sounds like the clutch on the compressor seized up for a moment, did you check the belt for damage? Also would be a good Idea to disconnect the pressure lines on the back of the compressor and check for metal shavings in the lines and the compressor.
Old May 12, 2009 | 03:58 PM
jerry007's Avatar
I never had the smoke issue, nor any electrical problems. This is for anyone that owns a 2003. My truck was about 2 yrs old and it started bloing cool air then went down to warmer air. The longer the trip the warmer it got. I took it to a friend thats an excellent mechanic. He charged the system up, told me it was low to begin with, then cleaned the condenser really good. I have never had another issue since then. My A/C didn't work that good when I drove it off the lot with 12 miles on it!!!
Old May 12, 2009 | 05:29 PM
randallp84's Avatar
Just guessing, but it sounds like maybe your compressor clutch was slipping due to unusually high pressure and the smoke could have been the pressure relief valve blowing off a little refrigerant.
cyawallac
Nov 1, 2011 11:37 PM
MiniC
Apr 20, 2009 08:58 PM
rossco
Aug 23, 2007 06:17 PM
BigDodge1
Nov 21, 2005 12:59 PM
