what to do if ball joint bore on axle is sloppy?
Old Jun 19, 2013 | 06:15 PM
sallyman1's Avatar
i just got my carli ball joints. i pressed out the old xrf pieces of manure (**** in 16,000 km). anyways the top will be a snug interference press fit, but both lowers can be put in by hand. they will actually fall out unless i put snap ring on. do i coat them with green loctite or JB weld (epoxy). or just never seize and leave it? i dont know what to do and truck is apart
Old Jun 19, 2013 | 06:32 PM
59Diesel's Avatar
I done my 03 4x4 a few weeks ago...none of em just "fell out", top or bottom, but not too difficult with the correct press. and putting em in, I heated up the housing with a bottle torch (not a cutting torch so dont get too hot) just enough with a little bottle, and had the balljoints in the freezer a few hours prior to install, they go in pretty easy that way... I didnt use any epoxy but did neverseize em for what its worth.
Old Jun 19, 2013 | 06:44 PM
sallyman1's Avatar
you dont understand what i mean. i got the NEW CARLI ball joints in my hand. when i goto press them in the bottom i dont have to because i can put them in by hand. they actually almost wobble in the axle bore. i dont need a torch if anything i need to FREEZE the axle. get what i mean? the axle bore holes on the bottom are more than a slip fit. should i add epoxy jb weld or green loctite sleeve retainer to the bottom carli ball joints?
Old Jun 20, 2013 | 07:08 AM
Hintonc393's Avatar
I don't think any kind of epoxy or loctite will hold those suckers in. Having just replaced mine I know how tight they are going in and coming out. Have you called Carli and talked to them about it?
Old Jun 20, 2013 | 08:21 AM
59Diesel's Avatar
Yea I agree, sounds like they either sent you the wrong ones or your joint holes are in bad shape. No way they should be loose at all....Definitely be giving them a call, and I understand your in a tight spot with the truck apart, but I think if you went ahead with it your gonna have big problems, not to mention ruining new BJoints, and parts on your truck.......
Old Jun 20, 2013 | 11:11 AM
Hintonc393's Avatar
Ask Carli about tack welding the ball joint and see what they say. I cant see a tack weld hurting that ball joint.
Old Jun 20, 2013 | 11:24 PM
sallyman1's Avatar
I have no time for carli. I peened the circumference with a punch.they actually pressed in somewhat. I coated bore with jb weld
Old Jun 21, 2013 | 09:59 AM
Danderson's Avatar
Dynatrac offers knurled ones for those of you who used XRF's in the past.
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
