Weird electrical/regulator problem
Old Jan 13, 2016 | 09:24 PM
gunnygorge's Avatar
Got a weird problem. When I start the truck it seems the electrical power goes up and down. Lights go bright and dim, fan motor up and down. When I rev it at or above 1000 rpm its seems ok. Dash voltage meter also up and down.
Batteries are pretty new. Cranks well when starting, even below 0. Could it be a faulty voltage regulator?
Truck is a 2007 2500 Megacab 4x4, automatic, 5.9, auto, 53,000 miles.
Old Jan 13, 2016 | 10:34 PM
Mexstan's Avatar
Maybe this is not a problem, nor is it weird. Have you considered that what you are seeing is the grid heaters cycling? They pull a lot of amps. The "problem" goes away once the engine warms up a bit.
Do a search here and you will find other references to this so-called "problem".
Check this out: https://www.dieseltruckresource.com/...d-start-57485/
Old Jan 14, 2016 | 07:32 PM
ftltmp's Avatar
Old Jan 15, 2016 | 07:57 AM
gunnygorge's Avatar
Thanks. This is the first Ram Diesel I've had, so I am unfamiliar with some of the things this truck does compared to others.
Old Jan 15, 2016 | 08:02 AM
MikeyB's Avatar
Typically the heater grid is enabled when the ambient intake temperature is below 65 F.
dunl
Jun 20, 2010 07:38 PM
Common
Apr 9, 2008 10:25 PM
psdctd
Feb 17, 2004 09:21 PM
turbospl311
Oct 14, 2002 08:23 AM
