weird 1-2-1 shifting????
Old May 10, 2007 | 01:35 PM
0lywrench's Avatar
Im not sure on other years but the 06 and 07 dont have the throttle cable,we have a motor actuator controlled by the computer,from what ive been told(dodge tranny tech,independent trannt guy )the programming for the torque curve is what is wrong,I bought a transgo shift kit,didnt help,then i bought a bd diesel valve body,didnt help.I then bought a tranny controler from dtt and it helped about 90% of the problem.It goes into the shop monday for a torque converter and to have the vb pressures adjusted and this will hopefully cure the rest
Old May 14, 2007 | 09:03 AM
Rollin' Smoke's Avatar
so does the 03's have the TV cable?
if so the I would be curious to find out how you adjust it properly!
Old May 14, 2007 | 11:44 AM
3500eh's Avatar
not sure what a tv cable is, but tranny guy did not put a cable that goes from tranny to motor on properly. he explained it like this to me. - cable is in a hard spot to get at on motor, cable was sitting on nuckle not over it as it shouldve been. he fixed it and that cured my 1 2 1 2 shift prob
Old May 14, 2007 | 11:53 AM
BigDave12768's Avatar
Originally Posted by wreedCTD
are you going to explain your statement?
Dodge knows that 2nd gear bands r coming out of adjustment on a regular basis and are fixing them under the 7/70 warranty. My truck is at dealer now because of the bands needing adjustment. Not sure is this is the same problem that he is speaking of. But 2nd gear is a know problem on the 04-05 trucks
Old May 15, 2007 | 01:31 PM
do you have anymore detail than this......really kinda of confused from that description, thanks
Old May 15, 2007 | 02:11 PM
3500eh's Avatar
not really. sorry. good luck
Common
Apr 9, 2008 10:25 PM
A-Poc
Sep 2, 2005 02:46 PM
guzzirider
Mar 5, 2005 03:21 PM
MoreSmoke
Feb 6, 2004 09:36 AM
bigtobe
Oct 28, 2003 03:19 PM
