want smoke!!!
Old Jan 5, 2010 | 12:49 PM
Clane's Avatar
Originally Posted by gotsmoke05
Just bought an early 04 2500 with 130000 on it. I am lookin for a way to make smoke on my tight budget. I don't know a whole lot about mechanicin but i got some buddies that are pretty good. Any easy suggestions? Also whats the best exhaust...loud but not annoying.
Muffler delete pipe. Sounds good and less then 100 bucks.
as for making smoke on a tight budget you could try
1) Drain all coolant then drive at freeway speeds for 30 minutes
2) Add fuel to crankcase.........^^^^^
3) Pour one quart of oil on hot exhaust manifold...
^ I'm joking of course on "ways to make your truck smoke"....
Welcome to the site!
Old Jan 5, 2010 | 01:25 PM
Sevir's Avatar
I heard you can throw a plastic bag over your air intake filter for some smoke.
To answer your questions, a fuel pump and a programmer will give you everything you need to bellow out the smoke.
On a cheap budget, someone mentioned it already, but there is a switch you can install that makes your ECM think you are at full boost and will give you 100% fueling.
I would recommend starting with a edge or bully dog and build up from there.
Old Jan 5, 2010 | 06:34 PM
gotsmoke05's Avatar
Thanks to all you who gave good advice, thats what i was looking for. I will look into all of the suggestions!!!
Old Jan 9, 2010 | 07:07 PM
BAD GRAVY's Avatar
welcome got smoke 05. i was asking the same question months ago on here.i got the same B.S. from all those tree huggers also...do what you want,its your truck edge juice with attitude,some injectors did the job for me! Happy Smoking
withalligators
Oct 8, 2014 10:22 PM
2171CTD
Feb 20, 2012 04:16 AM
I PASS GAS
Jan 25, 2006 07:51 PM
BigDan
31
Jan 22, 2006 01:05 PM
ox
21
Oct 14, 2002 12:01 AM
