Want to replace OEM fuel filter banjo bolt & fitting
Old Jan 31, 2012 | 04:41 PM
ppsi's Avatar
I would like to reconfigure a job I did in adding a separate lift pump & filter. I originally ran braided line from the tank supply line to the filter adapter and into the fuel pump. I used the stock rubber hose from the pump to the filter canister. I put another fuel pump on and the rubber hose is too short going to the filter canister so I had to use a piece of braided line and getting it over the fitting that is attached to the canister was very hard at best. I'd like to get a high flow adapter/banjo bolt to replace the one on the canister but could only find full kits or adapter for 2002 and back. Can someone offer a source for a 3/8 adapter & banjo bolt for the 2004? I want to go back with push lock & diesel approved line.
Thanks
Howard
Tommy93w350
Nov 16, 2016 06:40 AM
Moobesor
Jul 15, 2008 03:07 PM
jmccart
Jan 26, 2008 07:36 PM
ptgarcia
Aug 18, 2006 03:52 PM
Big Smoky
Mar 6, 2006 10:47 PM
