Vibrations!
Old Mar 13, 2007 | 03:29 PM
  #31
ClackClack's Avatar
Mine turned out to be a tire with a slipped belt. No more vibration here!
Old Mar 13, 2007 | 08:10 PM
  #32
hobbes2's Avatar
I had the vib for 2 years on my o5 no one could figure it out. I finally solved the problem. traded. I think there is a combo of issues all put together. 1 a cummins is a lot of motor and as in my larger trucks they vibrate. 2 Very rigid frame ( good for heavy work) but transmits vibes better. 3 Pinion angle issues, we improved our truck a bit with 4 degree shim. Good luck
Old Mar 13, 2007 | 09:06 PM
  #33
LovinTheTorque's Avatar
mine too
My truck also has the vibe going to check slip joint. My vibe is so bad tranfer case is leaking @ rear seal where the joint slips on and at the first bolted split. Got to fix it soon bugging me !!!
Old Mar 19, 2007 | 07:04 PM
  #34
4x4not's Avatar
So far the vibration problem with my truck is not fixed either. I think I'm going to take the truck back to the dealer once again in a couple weeks. This time I am MAKING them physically check some parts instead of driving it, deciding it isn't bad enough to warrent a fix, and then telling me it is NORMAL.
msatow
32
Jan 13, 2005 01:09 PM
030303
Dec 15, 2004 06:34 PM
TurboTed
Sep 2, 2004 08:28 AM
Todd Hoffman
Mar 31, 2004 07:52 PM
Paul S.
Mar 31, 2003 08:59 AM
