vibration at 55mph
Old May 3, 2009 | 12:48 PM
Kevin Krieger's Avatar
vibration at 55mph
I have an anoying vibration at 55mph. It is not there until 55 and stops at 60mph. u joints are fine and I had tires balanced several times. I finally put on centramatic wheel balancers. Vibration still there. I have a leveling kit on truck and dealer says it is just the bfg mud terrains that are doing it. I have heard talk on the forum about a one piece driveline. I don't have a launch shudder problem. Is anyone having my problem that has put the one piece driveline on and has it gone away? About ready to order a one piece. Thanks
Old May 3, 2009 | 05:45 PM
anyone have any info?
Old May 3, 2009 | 06:17 PM
cody459's Avatar
Mine did the same thing though it was 60mph and quit at 65, quit though after replacing my injectors, but that could have been a coincidence. I would take it somewhere besides dodge and make them ride with you and start checking out the easy stuff before jumping at the big stuff.
Old Jun 19, 2009 | 10:43 PM
zking's Avatar
same problem!almost feels like mud tires but im running michelin street tires.only happens at 55 i replaced my 2 piece with the fancy alluminum 1 piece 08 drive shaft and the problem is still there. talking to people that has the same problem they say that all dodges do it some what.i love this truck though. wander if it could be rear end noise? i just try not driving 55!
Old Jun 20, 2009 | 01:19 AM
dslpwr81's Avatar
It is your front driveline spinning. Most report this issue at around 55mph. Normal.
Old Jun 20, 2009 | 09:00 AM
fl dodge's Avatar
i removed my front drive shaft and it heped alot with the vibration, it may be worth giving it a try ,i also had my drive shaft balanced while it was out and it was out quite a bit but i did not re-install it yet to see how much difference it actually made.
NCFisherman
27
Feb 27, 2008 09:14 AM
Mcc2430
Feb 10, 2008 07:04 PM
jimk403
Feb 3, 2007 08:51 AM
john henry
Jul 13, 2005 01:07 PM
fishermansteve
Mar 31, 2003 09:29 AM
