Vib. Gone After 5000 Miles
Old Jun 1, 2005 | 08:15 AM
hobbes2's Avatar
Smile Vib. Gone After 5000 Miles
After Leveling kit was installed (1.5 inch) at about 2000 miles my truck vibed at about 1200 to 1600 rpm , Pedals ,seats ,floor ,then smooth to 85 mph. Did not think it could be the kit or drive angles because of the small amount of lift, only 1.5 in 0r 2 in tops. We checked everthing on install , also exaust and tires , could not shake the Vib. Finally we removed the new 2 inch taller front coils and went back to stock . Now the truck runs smooth as silk from idle on up to 2500 rpm in all gears. We now have taken the rest of the after market suspension off and back to stock. I have done lifts on trucks before , can anyone explain why such a problem with pinion angles on this truck with a small 1.5 inch difference . Also why the vib did not continue through to higher rpm and speeds as it does with bad driveline angles? Love the truck vib free !
Old Jun 1, 2005 | 08:26 AM
jkitterman's Avatar
What are your truck specs. Fill in a sig so we can guess better.
Old Jun 1, 2005 | 08:36 AM
hobbes2's Avatar
I filled out a sig but it does not display ?
Old Jun 1, 2005 | 12:51 PM
hobbes2's Avatar
Truck specs . 2005 cummins dually 6spd. 5th wheel kore suspension ( not anymore) and Rip Rook pipes.
Old Jun 2, 2005 | 07:01 AM
hobbes2's Avatar
Anyone else had this happen with level kit. Is there a way to correct it with kit on . I like the improved ride of kore. Thanks
Old Jun 3, 2005 | 11:44 AM
kry226's Avatar
My vibe smoothed out after Kore install.
Old Jun 3, 2005 | 05:06 PM
hobbes2's Avatar
Was your vib passing through 1400 to 1600 rpm on accel. then smooth ? Who knows whats up with all these vibs. I guess its just part of having a cummins .
cbrahs
Nov 1, 2011 11:00 AM
dieselnewbie
Oct 27, 2006 07:38 AM
WACTD
Jun 13, 2006 07:49 AM
guidster
Jun 23, 2004 07:07 PM
Mopar_Mudder
Mar 14, 2003 09:43 PM
