Very Rough Idle At Start Up
Old Mar 4, 2009 | 11:46 AM
M1AM14SPUR's Avatar
Question Very Rough Idle At Start Up
I have a block heater for my truck, but when I start up, she idles really rough. Once she is warmed up, there aren't any problems.
Anyone have an idea of what is going on?
Thanks-
Eric
Old Mar 4, 2009 | 05:12 PM
Texasimport's Avatar
Any smoke? if white, you might try some injector cleaner to start. Some folks here feel rough idle and some white smoke during cold morning starts are the norm but not sure I agree. My experience is only with 3 CTD over the past 10 years and the only times I got rough idle on cold mornings WITH some White smoke is when I had dirty injectors.
The idea is the dirty injector gets sticky and a little bit of fuel leaks into the cylinder over night.
Old Mar 4, 2009 | 05:40 PM
wwm's Avatar
wwm
it may just be because it is cold, my truck starts up rough when it is about 40 outside, but you say it does go away, so there should be any problem
Old Mar 5, 2009 | 03:20 AM
SuperGewl's Avatar
Are you reving the engine up to about 1k after starting per the instructions on the visor? What type of oil are you using? 100% Synth oil doesn't see it as often because it flows better at lower temps. When was the last time you changed the oil and the fuel filter?
Old Mar 5, 2009 | 08:34 AM
M1AM14SPUR's Avatar
3,000 miles ago on both. I use rotella oil. My truck is a manual and doesn't have that information on the visor.
Old Mar 5, 2009 | 11:03 PM
mini14's Avatar
my truck had spuratic rough idle, 2 days ago i installed a rokktech, it hasnt done it yet. take a look at the crank sensor head, mine had a pretty thick layer of crude on it..idk if i had just cleaned the stock sensor it might have helped, but im glad i got the rokktech in cauz it runs and sound a whole lot better then before.
Old Mar 6, 2009 | 07:48 AM
MotorCityMadman's Avatar
Mine idled very rough on cold starts. I finally figured out that I had picked up some poor quality diesel. A dose of Howe's Meaner Cleaner and some Power Service along with a new fuel filter cured it in 1/4 of a tank.
Old Mar 6, 2009 | 11:06 AM
M1AM14SPUR's Avatar
What is a rokktech? A programmer?
If it was my crank position sensor, my pda would show a tuner fault. I put some Lucas injestor cleaner in yesterday, I will be starting her up in a few minutes and see how she feels.
Old Mar 6, 2009 | 11:29 PM
mini14's Avatar
by reving in cold weather you force the ecm to change timing
Txbigfoot
Feb 26, 2013 03:24 PM
Burning Oil
Aug 1, 2010 04:09 PM
Aosipower
17
Oct 3, 2007 09:54 PM
elirandolph
17
Jul 17, 2006 07:14 PM
01dodge2500stoc
Jan 26, 2006 10:07 AM
