Valve body bolt torque?
Old May 29, 2006 | 10:50 AM
eastmentCTD600's Avatar
Changing the tranny fluid on my '04.5 48RE and would like to know if anyone has the torque spec. for the bolts that hold the valve body to the tranny case?
Anyone know?
Thanks!
Eric
Old May 29, 2006 | 08:36 PM
lmills's Avatar
100 in lbs on the valvebody, 53 in lbs on the filter bolts
Old May 29, 2006 | 10:39 PM
N.Johnson's Avatar
If a guy wants to get the most tranny fluid out leave the valve body bolts alone. Let your truck sit overnight and drop the pan. Change the filter, clean the pan and magnet, bolt pan up and refill. Now it takes two men, one cracking the tranny outline to bleed the converter and other to start/stop the truck in neutral. The 48re doesn't pump fluid in park without a tranny mod. Buy at least 20 quarts of ATF4 or whatever floats your boat. Don't mess with a valve body if your auto is good to start....... Is this what you were thinking eastmentCTD600?
Boat_Guy
Dec 9, 2011 11:18 AM
mainer
Jul 17, 2007 07:13 PM
whttacoma
Nov 25, 2005 07:29 PM
MoparRiggan
May 16, 2005 09:21 PM
midwestdually
24
Dec 6, 2004 08:10 AM
