Cab/body mount bolt torque?
Old Jan 17, 2011 | 03:03 PM
Boat_Guy's Avatar
So, I replaced my cab and radiator support mounts with the Energy Suspension poly mount bushings and I was wondering if anyone can tell me what the torque specs are for the cab and rad support bolts, other than just "good-n-tight".
Thanks,
Darin
Old Jan 18, 2011 | 10:48 PM
Boat_Guy's Avatar
Just an update to let others know:
I have a parts truck so I decided to progressively back off the cab bolts with a torque wrench and see what value they broke free at. It seems to be around 40- 45 ft/lbs. So I'm going with 45 ft/lbs with some red loc-tite. I'll recheck them after driving a bit and see if everything stays in place.
Also, found a manual that said the truck bed bolts were supposed to be at 35 ft/lbs. I'm not doing the bed right now but thought that was a bit on the low side. Just thought I'd mention it in case anyone can confirm it.
Darin
Old Dec 8, 2011 | 09:48 PM
jimbo486's Avatar
Can anyone confirm torque specs? I just changed mine out and looked through the FSM several times and could only come up with a chart with torque specs for grade 5 and 8 SAE bolts, not metric. It only describes the grading for metric bolts and the increasing number means the increased strength but that doesn't tell me anything about a torque. It has 10.2 or 10.9 stamped on the head which makes it metric, it took a 3/4" socket on the head. If my memory serves me correct, that's equal to a 19mm which would yield a 12-13mm thread, equal to about 1/2"? Could I just torque them to specs for a 1/2"-20 bolt?
Old Dec 9, 2011 | 08:42 AM
maybe368's Avatar
Here is a metric torque chart...Mark
Old Dec 9, 2011 | 11:18 AM
jimbo486's Avatar
Thanks, Mark! Looks like it'll be about 69-70ft. lbs being as I applied some anti-sieze to the threads.
BearKiller
May 17, 2016 09:55 PM
wrenchmaster
Jul 26, 2009 08:16 PM
itr.#1446
May 10, 2008 07:30 PM
mainer
Jul 17, 2007 07:13 PM
eastmentCTD600
May 29, 2006 10:39 PM
