Vacuum Pump
Old Mar 4, 2008 | 07:58 PM
mjsandt's Avatar
Vacuum Pump
I just posted a similar thread in non-drivetrain, but have located the problem. My vacuum pump is going crazy and not shutting off at all. I havent checked my cruise control to see if it still works, but the pump is making a lot of noise and doesnt shut off. What could be the problem? I zip-tied the connections and checked the hose for leaks, but still nothing. There is a white nipple sticking out of the bottom that blows air out when the pump is on, and there is no hose connected to it, should there be? I dont want to burn the pump up, and plus the noise is driving me crazy. It used to turn on and run for a few seconds and shut off, and cycle when neccessary while running, but now it runs non-stop. Any help is greatly appreciated. Thanks.
MSandt
Old Mar 4, 2008 | 11:23 PM
dozer12216's Avatar
I may be wrong, but believe pump vents internal to engine. Can cause excess blowby issue if has vacaum leak in hoses, ect. You may already have a fubarred V pump.
coalburner_77
17
Nov 7, 2018 07:36 PM
jimbo486
May 8, 2016 06:07 PM
powerstrokin03
Mar 19, 2007 01:00 PM
amartinson
0
May 4, 2003 01:55 PM
