UOA Amsoil 15W40 any ideas?
Old Jun 20, 2007 | 07:26 PM
D-Roc's Avatar
Here is the results from my latest UOA. Iron is high again. THis is my second time with synthetic and the second time iron is high. Mileage-13000 km's (about 8000 miles), mostly city driven, Blackstone Labs UOA.
Aluminum 3
Chromium 1
Iron 49
Copper 3
Lead 2
Tin 4
Molybdenum 6
Nickel 1
Manganese 1
Silver 1
Titanium 0
Potassium 5
Boron 4
Silicon 4
Sodium 3
Calcium 3460
Magnesium 10
Phosphorus 1026
Zinc 1297
Barium 0
SUS viscosity 69.1, (should be between 68-80)
So, this is my second UOA with HIGH IRON- you could probably find my last UOA from a few months back. Esso XD3 0W40 was used.
What does it look like the problem is? Two consecutive UOA's with high Iron. Same driving conditions, same mileage. Do I need to drop my interval, or change my oil? ANybody have any ideas?
Old Jun 21, 2007 | 10:08 AM
desertdieselboy's Avatar
Aluminum 3
Chromium 1
Iron 49
Copper 3
Lead 2
Tin 4
Molybdenum 6
Nickel 1
Manganese 1
Silver 1
Titanium 0
Potassium 5
Boron 4
Silicon 4
Sodium 3
Calcium 3460
Magnesium 10
Phosphorus 1026
Zinc 1297
Barium 0
I`d talk with Amsoil. I knew a guy that did the oil analysis, his keep coming back with water-7 years later the head gasket went...
Iron..has to be block wear. These engines are built really tight, that`s why you see fuel mileage change ~60-80K miles.
Old Jun 21, 2007 | 12:15 PM
DBLR's Avatar
If you only have 8,000 miles on the engine then its most likely not yet broke in all the way. Some engines can take 25,000 miles to get broke in if the truck does not haul or tow any weight. That is why its a good idea to not use synthetic oil until its had 10,000 miles on it along with some hard work during those first 10,000 miles.
Old Jun 21, 2007 | 02:07 PM
Spooler's Avatar
I waited until 30,000 miles to swap my truck over to synthetic. Your wear will be minimal after the swap. I wanted to make sure the motor was broke in good.
Old Jun 21, 2007 | 06:05 PM
D-Roc's Avatar
My mistake, should have been more specific. There was 13 000 km's on the oil when sampled. I have 61 000km's on the engine. Started synthetic at 35 000 (around 20 000 miles).
DBLR
Oct 26, 2009 02:27 PM
bishgeo
Oct 22, 2009 12:43 AM
sallyman1
16
Feb 9, 2009 01:36 PM
GlennRMK
17
Apr 22, 2008 08:41 AM
wood_n_soldier
Jul 8, 2004 08:09 AM
