Rotella 5w40 synthetic vs Amsoil 15w40?
Old Apr 16, 2008 | 08:56 PM
GlennRMK's Avatar
Opinions?
Was running the Amsoil 15w40 Premium Marine(AME) for the last 30k in my old truck. It has gone up considerably and now 3 gallons is about $60(Dealer cost).
I have access to Rotella Synthetic 5w40 for $38.37 for 3 gallons(I work at an auto parts store).
Is the Amsoil worth the coin? Been really happy with their products, but for $22 less an oil change I might change my mind.
Whats the gel/freezing point on the Rotella?
Thanks for the feedback
Old Apr 16, 2008 | 09:29 PM
SundayMoney's Avatar
For $22 every 7500 miles I'd stick with the true (group 4) synthetic.
The Rotella is good stuff,but its just a highly refined dino oil.
Old Apr 16, 2008 | 09:36 PM
TriSum's Avatar
Glenn,
P.M. me an email address and I will send you a very interesting oil survey article that might help you with your decision.
David
Old Apr 16, 2008 | 10:51 PM
snoyes's Avatar
I know we ran the rotella 5W-40 in Alaska with pretty good luck in the cold. However, coldest I ever had the oil in was about -30/-35. Getting much colder than that I start worrying about the fuel first...
Old Apr 17, 2008 | 06:53 AM
Hounddog's Avatar
Amsoil is a group 4 oil.The Rotella is a group 3.You do get what you pay for sometimes.Biggest differance I've read about is the Rotella is not capeable of extended drain intervals.I'm sure theres some other differances also.I order Amsoil direct and have been a preferred customer for years for a price break.To me its like owning a diesel.I have to have a tow vehicle and the thought of going back to a gas burner dosen't enter my mind.I use Amsoil products and never really think about using anything else.Its in my lawnmower LOL.
Old Apr 17, 2008 | 03:46 PM
2006Mega's Avatar
rotella 5w-40 smells wierd everytime i have the windows open when stopped or part it and get out. its a hard to describe smell, not bad not good.
Old Apr 17, 2008 | 06:57 PM
timcasbolt's Avatar
I'm pretty happy with the Rotella 5w40. Wouldn't consider switching.
Old Apr 17, 2008 | 07:21 PM
GasganoFJ60's Avatar
How long can you run on Rotella? Just 7500? AmsOil should be able to run 15k at least. Depending on filter setup you could stretch Amsoil out to 25k, 50k, or even never do a full oil change again, just change filters and top off. Amsoils high price should more than pay for itself.
Old Apr 18, 2008 | 07:01 AM
D-Roc's Avatar
Run UOA to find out what works better for yourself...then you can make a decision from there. I used to agonize over Delo 400 15W40 or Amsoil- then I sent UOA's in and guess what? I'm still using Delo 400...
Old Apr 18, 2008 | 09:19 AM
booman70's Avatar
Second that Ive run both Rotella and Delo and sent in oil analysis on both and am currently using Rotella but feel comfortable running either. Check out some oil reports and make your own decision!
Old Apr 18, 2008 | 07:03 PM
dozer12216's Avatar
I assure that your engine will never know the difference. All oils(additives and contamination) eventually fail, so forget the lifetime oil change. I futher assure you that complete loss of either oil will guarantee a failure in about the same time it. So if $20 a change extra gives you sufficent bragging rights, then go for it. I suggest a EOA and some extension of oil change interval is acceptable. All the major oil brands that meet oil spec requirments are plenty good enough. Read oil analysis(independent) as someone else recomended. Use good oil filter also.
Old Apr 19, 2008 | 04:09 PM
TAS05CTD610's Avatar
Go with what you want. I can say without a doubt that most 18 wheelers have been using rotella for years, and def. go more than 5,000 miles on an oil change. yes they hold 3 times the oil, but also have about 3 times the engine. As long as your oil is loading up (holding the dirt) filtering properly, you can get away with lots of oils. Syn is good, but unless you use it all up, again, how many 18 wheelers run it, vrs a conventional oil. I'm still running 15W-40, I should switch to 5w-40, but not worth the cost
Old Apr 19, 2008 | 04:48 PM
RMCBRIDE's Avatar
Rotella verus Amsoil
Has anyone checked out the new OilGuard kit that is on their web site. It is a bypass kit (EPS-20 DCE) with the mounting bracket and all of the other fittings. I run Rotella 5-40w and it seems great to me. I will be doing a Oil test right before 10,000 miles. I do run my oil that long and not had any problems. Since I said that I need to knock on wood. I would stay with Rotella myself. A OilGuard bypass filter would help keep your engine clean and GM did a test with OilGuard that said that it would make your engine last 8X the normal like with the Bypass filter. That means if I run to 100,000 miles without a Bypass that with a Bypass I can run to 800,000 miles. Man that is alot of miles. I do run a OilGuard filter on my truck. These trucks cost to much to not take care of them.
Old Apr 20, 2008 | 09:14 AM
GlennRMK's Avatar
Ordered some more AMSOIL. Doing the diffs too!
What kind of service intervals should I be doing? Most of my miles are like a 10-12 mile commute(faster two lane 45-70 MPH). Some highway. A little towing, but not much.
I was doing about every 7k on my 01. Was using K&N oil filters, which I've heard are made by Baldwin.
I get the best prices on these(About $10) or I can get Mobil One filters for about $8.
Thanks
