Universal Joints
Old Sep 1, 2009 | 05:52 PM
Casey Balvert's Avatar
Universal Joints
Any recommendations for replacement U-joints (greasable) on a 2003 3500 quad cab dually? Thinking of replacing them as a preventative measure. Casey
Old Sep 2, 2009 | 12:10 AM
TonyB's Avatar
IIRC, the consensus is Spicer U-joints. I think they are available at NAPA. Search the site for 'spicer'; that should get you PN's.
Tony
Old Sep 5, 2009 | 10:21 PM
04 Diesel's Avatar
I just got a Percision u joint, made in the USA and greasable. Got it at Napa.
Old Nov 11, 2009 | 08:08 PM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
are the " Precision U joint " brand adequate ? noticed my u joints were trashed tonight and went ahead and bought the precision brand from napa.
Old Nov 12, 2009 | 09:38 AM
Squidward's Avatar
how many miles should factory u joints last? I've got about 95K miles on my truck, and I'm starting to think maybe I should replace them, even though they're not causing any problems right now.
Old Nov 12, 2009 | 10:32 AM
tslewisz's Avatar
Both the center and rear UJ's on my '05 have been replaced and I'm at 62,000 miles.
Old Nov 12, 2009 | 11:57 AM
WOW, I am at 186K on the originals.
Old Nov 12, 2009 | 08:28 PM
Pikeman's Avatar
Between the front axle and both driveshafts I have replaced 5 so far on my 06 between 35,000 and 80,000. I am really getting frustrated with always having a popping noise going on. Maybe they had a bad lot of em or the hard winters up here do em in fast.
Old Nov 13, 2009 | 08:01 AM
Swayse's Avatar
My first u joint went at around 45k.
Old Nov 13, 2009 | 10:52 AM
pdogg's Avatar
Is this more of a 4x4 thing? seems the 2WD trucks are less prone to UJ failures..
Old Nov 13, 2009 | 04:12 PM
Pikeman's Avatar
2WD trucks only have 2 ujoints on the rear drive shaft. 4WD have 6 ujoints. Seems all my ujoint failures are in the front end and not the rear anyway.
Old Nov 13, 2009 | 04:22 PM
pdogg's Avatar
yeah, I was wondering if I should be worried about my 2... doesn't look like it..
Old Nov 13, 2009 | 05:37 PM
correction: I have three and its a 2wd, QC,SB 5 speed. . I do not know all the configurations of the setup.
Old Nov 13, 2009 | 07:32 PM
NickBeek's Avatar
I have had precision brand on my rear drive shaft for about 6 months now, so far so good. I just found out yesterday that the ujoint on my front axle that drives the wheel is bad. I picked up a Precision for that too at Orielly's Auto Parts. I only replace the crappy factory sealed for life joints with greasable joints, and I try to buy parts that are made here which all the Precision ujoints I have purchased are.
Old Nov 13, 2009 | 07:35 PM
trik396's Avatar
How did you figure out your front axle joint went south?
btw- I used Precision greasables in my driveshaft also. So far, so good.
