Ujoint's
Old Jun 3, 2008 | 04:56 PM
DrBoost's Avatar
Ujoint's
gettin a loud sqeel at about 10mph and lower from the driveshaft my buddy at work says it's the ujoint's crawled under there after work today and there's no play just wonder if anybody else has delt with this
Old Jun 3, 2008 | 05:07 PM
John Faughn's Avatar
Bad u-joints will not always have play , there may be pressure on the drive train locking up a lose joint , get all wheels of ground to see if there lose .
It could the u-joints , but until you find it , it could be a few things , just have to look with all wheels off ground and look for lose parts , anything that moves could be making sounds , but more often than not , squealing may be wheel bearings , brakes , but hard to say with out hearing , or getting more description .
Old Jun 3, 2008 | 09:42 PM
pullin hard's Avatar
i have replaced u joints like 5 times so far, never had one with play, they all dried up and rollers were no good.doesn't seem to matter if its a grease type or sealed, they don't seem to last, i do how ever put alot of miles on my truck.
Old Jun 3, 2008 | 11:20 PM
Det 1's Avatar
A bad U-joint will often heat up with use. After driving, get underneath and check by hand. I found one on my truck last summer with this method. Not very scientific, but effective.
Old Jun 4, 2008 | 01:15 AM
crash969's Avatar
If its comin from the front its most likly the axle shaft u-joints.
Old Jun 4, 2008 | 05:12 AM
ptm600's Avatar
The squealing is probably from a siezed up u-joint. Sealed joints and the grease drys out in them, they get hot and seize up. Mine sqealed also.
Old Jun 4, 2008 | 05:09 PM
DrBoost's Avatar
I bought new ujoint's the other day forged steel 21$ each just going to replace them both
joeel
Apr 4, 2007 08:27 PM
lucey
Oct 26, 2006 06:47 PM
pitr
Sep 3, 2006 08:55 PM
TrxR
Apr 15, 2006 09:18 AM
jaconst
Apr 7, 2006 10:45 PM
