TSB # for Lift Pump?
Old Dec 14, 2005 | 11:08 AM
The Wrench's Avatar
Hi All,
I am looking for the TSB # for the lift pump issue. I am having the retrofit done (kit 5715537-AA?).
I checked Genos website and did some searches here but can't find?
Thanks
Old Dec 14, 2005 | 11:39 AM
TRAVIST's Avatar
There is not tsb for the lift pump issue. The old lift pump part number simply supersedes to the new in tank part number. Which by the way if this is for your 2004 the number in your post is wrong. You will want part number 5175540AA if you have a 35 gallon tank and part number 5175539AA if you have a 34 gallon tank. The only thing that Dodge put out is a tech tip related to the fuel pressure testing on the new pumps. It reads as follows:
Tech Tip Part Description: In-Tank Fuel Pump Kit(s), In-Tank Fuel Pump
Tech Tip Description: When troubleshooting an In-Tank Fuel Transfer Pump installed on a 1998.5 - 2004 Diesel Ram, be sure to use the 2005 model year diagnostic manual. Fuel pump flow, NOT PRESSURE is the indicator of a good or bad fuel pump. All aftermarket devices used to identify low fuel pressure are incompatible with the In-Tank Transfer Pump and should be disregarded.
Hope this helps.
Travist
Old Dec 15, 2005 | 02:25 PM
RobbieH's Avatar
From experience... if they haven't already dropped the tank, do it now and make sure it's clean. You don't want them refusing warranty because of some crap in the tank like they did on me. $1280.
twhman
27
Jul 16, 2006 11:36 AM
ataboy9026
Dec 25, 2005 05:49 PM
Txwelder
May 19, 2005 06:10 PM
Adieselbrother
Mar 21, 2005 03:27 PM
t-15 firefighter
14
Oct 22, 2004 10:10 AM
