Tsb 21-009-07
Old Oct 6, 2007 | 01:33 PM
Mopard's Avatar
Tsb 21-009-07
for transmission.
48RE - 1-2 shift hunt under light throttle.
replace governor pressure solenoid valve in VB
Anyone know where I can print off this TSB to take to dealer? Can't find it at dodgeram.info
tia
Old Oct 6, 2007 | 01:39 PM
vzdude's Avatar
DTR's 'Go to Guy'
Here ya go!
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation.
SUBJECT:
48RE Transmission - 1-2 Shift Hunt At Light Throttle
OVERVIEW:
This bulletin involves the replacement of the governor pressure solenoid valve in the
transmission valve body.
MODELS:
2004 - 2007 (DR/DH/D1) Ram Truck (2500/3500)
SYMPTOM/CONDITION:
The customer may experience a 1-2 shift transmission hunt during light throttle application.
This condition may be due to a governor pressure solenoid valve.
DIAGNOSIS:
If the customer experiences the above condition perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 04617210 Valve, Governor Pressure Solenoid
4 05013457AA ATF+4 Automatic Transmission Fluid
AR 02464324AC Gasket, Transmission Oil Pan (Note: Original pan
gasket is reusable and should not require
replacement).
REPAIR PROCEDURE:
1. Raise the vehicle on a suitable lift. Turn the ignition switch to the “OFF” position.
Remove the ignition key from the ignition switch.
2. Remove the transmission fluid (oil) pan and pan gasket. Clean and save the pan
gasket for later use during reassembly.
3. Disengage the wire connector to the governor pressure solenoid valve (Fig. 1).
4. Remove the screws used to secure the governor pressure solenoid valve retainer to
the transmission valve body.
5. Remove the old governor pressure solenoid valve from the transmission valve body.
6. Clean the transmission housing and oil pan gasket surfaces.
7. Lubricate the o-rings on the new governor pressure solenoid valve.
8. Align the governor pressure solenoid valve to the bore in the valve body.
9. Install the governor pressure solenoid valve to the valve body.
NUMBER: 21-009-07
GROUP: Transmission
DATE: May 24, 2007
10. Install the governor pressure solenoid valve retainer and attaching screws to the valve
body.
11. Connect the wire connector to the governor pressure solenoid valve.
12. Install the transmission fluid (oil) pan and pan gasket (saved earlier) to the
transmission. Tighten attaching bolts to 13.6 Nm (125 in. lbs.).
Fig. 1 Governor Solenoid And Pressure Sensor
1 - GOVERNOR PRESSURE SENSOR
2 - GOVERNOR PRESSURE SOLENOID VALVE
3 - ELECTRONIC GOVERNOR
13. Lower vehicle.
14. Add automatic transmission fluid to the transmission.
15. Verify correct transmission fluid level.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: Description Amount
21-96-05-90 Valve, Transmission Governor
Pressure Solenoid - Replace (B)
0.7 Hrs.
FAILURE CODE:
ZZ Service Action
21-009-07 -2-
wreedCTD's Avatar
I'd also like to read it.
Old Oct 7, 2007 | 09:13 AM
Mopard's Avatar
thanks vzdude !
Old Jun 24, 2009 | 10:33 AM
Mlucas's Avatar
ok, i need te bump this post.
I have my truck in the dealership today to replace the steering components as per TSB 22-005-06-the tie rod ends, steering stablizer ect.
I am almost off of warranty & would like to have them drop out the tranny fluid while they are there-so basically, i think I have a 2-3 hunting problem, but since I didn't read up on it, i didn't really take note of the symptoms.
can someone tell me how ofter their tranny's shift back & forth when it is hunting. Mine only does it once or twice.....is this still in the books as hunting?
Old Jun 24, 2009 | 11:59 AM
Mlucas's Avatar
bump....
GOTMEAT
18
Jan 12, 2008 12:45 AM
GOTMEAT
Dec 19, 2007 01:56 PM
twhman
27
Jul 16, 2006 11:36 AM
Adieselbrother
Mar 21, 2005 03:27 PM
t-15 firefighter
14
Oct 22, 2004 10:10 AM
